Posts: 64 |
I have a Bassani on a stock y-pipe right now and I want to put a Sho Shop Y-Pipe on, but will I notice a diffrence in power, will there be a lot of rasp? Also I was thinking about buying a cat-less y-pipe just for the track, would a catless gain a lot of power or would I lose power because of less back pressure. And one last idea would a catless y-pipe sound good on a Bassani if I put in a good resonator ? Please give me some input for any of you guys that have tried these things before. Thanks a lot.
2000 CSVT BLACK w/ MODS
Posts: 1,812 |
Originally posted by JMSVT: I have a Bassani on a stock y-pipe right now and I want to put a Sho Shop Y-Pipe on, but will I notice a diffrence in power, will there be a lot of rasp? Yes, you should notice a nice gain in power. I would also expect some rasp, but I can only speak from experience w/ a ypipe (with a cat) and a stock SVT exhaust w/o a resonator. That setup was droney and raspy. Also I was thinking about buying a cat-less y-pipe just for the track, would a catless gain a lot of power or would I lose power because of less back pressure. I'd bet you would get a few extra hp. And one last idea would a catless y-pipe sound good on a Bassani if I put in a good resonator ? Please give me some input for any of you guys that have tried these things before. Thanks a lot. Haven't tried it, but it would probably sound good.  A lack of a main cat definately makes our cars loud.
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 3,248 |
I have the Bassani and thought it was too loud (nice loud but loud) with or withour tip resonators. Added an inline 4" straight through resonator and now think the sound is perfect..slightly louder than stock, but still deep, no rasp, nil drone. I have the MSDS Y-ppe which is louder than stock but retains stock cat so it is not as loud as catless Y. I "suspect" that with both a catless Y and a resonator, the car would be about as loud as a standard Bassani with stock y (ie no cat and resonator cancel out).. But just an educated guess, I could be wrong..
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 49 |
If I went with the Bassani set up would I also have to buy a y-pipe? I don't have a SVT.
Posts: 1,048 |
the bassani is from the cat back.y pipe not included.
Anthony 98 black Csvt #630 of 6535
Posts: 1,812 |
Doug, no you wouldn't need to get a different ypipe. I will warn you, though...modding is addictive.
Posts: 154 |
I had the Bassani with the MSDS headers & Y-pipe, it was very, very loud!!! Great performance though!!
2001 Mercury Cougar Aerogear WideBody Kit, Aerogear Carbon Fiber Hood 3.0 Hybrid 251hp and 229tq at the front wheels Eibach springs, Koni Stuts, Aussie Bar, ST200 R Strut bar, OMP front Strut bar, 19" RPM's 235/35-19 Nitto 555's All Alpine System - IVA-C801, DHA-s680, NVE-N852A, TCS-V430A, TMX-R705, TME-M580 x2, PXA-H900, MRD-M500 x2, MRV-f540 x2, SPS-0829, SPX-F17t, SPX-17m x2, SWR-1021D x4, RUX-4280 http://www.geocities.com/socal_neco/jimmy.htm
Posts: 79 |
You'll notice a big difference in power with the cat y-pipe powerwise (after it breaks in). It will be loud and raspy and droney. I took mine off for a while cause it was getting to me. Try it out and see if it's too loud for you and add a res if you want. I would.
Old - 95.5 SE with lot's of mods. New - 98 Black SVT with few mods.
Posts: 125 |
I have the Sho-Shop y-pipe w/cat and the Bassani. I disagree with those that say it is too loud. There is only rasp when cold and no drone. I really like it. I am also running with a Vortech SC.
Jim
98.5 SVT, Vortech SC, Bassani, Quaiffe, Clutchmasters Stg. 3, BAT Sport Springs/Konis, 17" Momo Arrows, Sparco Brace,BAT 22mm Sway Bar, PIAA fogs & headlights.
