#16048 05/17/02 12:12 PM
According to the Ford TSP (Technical Service Publication):
Idle Air Control (IAC) Valve
CAUTION:
Do not use Carburetor Tune-Up Cleaner D9AZ-19579-AA or BA (ESR-M14P9-A) or any other type solvent or damage to the valve internal components may result.
The idle air control valve (IAC valve) (9F715) cannot be cleaned. The idle air control valve must be replaced.
Also:
Throttle Body
The throttle body (9E926) for this vehicle is a sludge resistant design with a coating on the bore and plate. Sludge accumulation will not affect the throttle body airflow. Any attempt to clean the bore and plate area will impair the effectiveness of the coating. DO NOT clean the bore and plate area of the throttle body.
Both of these statements indicate that cleaning the IAC and TB is NOT recommended, yet I have seen a lot of posts to the contrary.
If these statements by Ford are correct, then why is everyone cleaning their parts?
Is it that most people figure that if they need to replace the part anyhow, then they will try to clean it first and see if that helps?
Or are the Ford statements incorrect?
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
I agree with the IAC valve - I wouldn't clean that - its too sensitive of a part and doesn't really get dirty anyway.
The throttle body plate though is one that I have cleaned. The Teflon coating doesn't do anything to begin with, as the damned thing gets totally coated with carbon and sludge. I also used a cleaner that claimed it didn't damage such coatings. I mean the whole point of the coating is to prevent carbon and sludge build up from sticking. But if its already on there, then the point of the coating is already lost. IMO, a clean throttle body with no Teflon coating is better than a Teflon coated throttle body loaded with carbon and sludge.
'96 Contour SE, black / opal grey, MTX, every option, KKM intake, resonator removed, Flowmaster Series 40 DeltaFlow, GoodYear Eagle HP's, 115k miles, new paint 7/01. Driven cross-country 4 times.
'70 Corvette Stingray Coupe, Cortez Silver, 454 bored to 462, Muncie M21, too many mods to list, lots of fun. 335 rwhp / 365 rwtq
'02 Corvette Z06, Electron Blue / Black, every option. Stock for now...
true, take a look at the plate on your TB and you'll throw that article out the window...the IAC valve I agree with as well, though I think I need to replace mine anyway, the car mooses if I shift when the secondaries are opening....actually sometimes I can hear it faintly when just driving in gear and the secondaries begin to open...rather annoying
1999 Silver Frost SVT
#609 of 2760
Born on 12/3/98
KKM Intake
Removed Resonator
35% Window Tint all around
Tinted Tail Lights
ElKy Mesh Grilles
HID
Dyno'ed at 175.3HP/155.5TQ
