Posts: 133 |
2- Kicker Solo X 12" (2500w rms & 5000w Peak 2ohm DVC) or 2- Kicker L7 15" (1000w rms & 2000w Peak 2ohm DVC)
with 1- Kicker KX2500.1 (2500w mono output) Each sub will recieve 1250 max wattage from the wiring sequence
The question is for the maximum boom with the amount of power at hand which sub will perform better?
(Enclosure depends on the outcome of my research)
Posts: 1,017 |
if they're getting 1250 watts, and the 15" only handles 1000 RMS, when you really crank it you'll get some distortion and will probably damage the sub. if you want more "boom", smaller subs tend to have a tighter, punchier bass. bigger subs tend to be able to handle lower frequencies and the bass carries better, but my vote would go for the 12"s
1995 SE
2.5L V6/MTX
187k
Posts: 4,639 |
u could build a bandpass box for the 12s to get it boomy. gotta guess a bandpass for a 15 will be huge. thats alot of power. r u sure u really need all that? or do u just want to be able to tell people that your system is 4million watts. is your front stage getting lots of power too? that might be way out of balance if the front is getting very little power.
Hugo AIM:omegazodiac
Posts: 566 |
How about this.... pick the speakers that sound the best to you.
If these two choices have met all your other criteria (price, power handling, enclosure size, etc) then go listen to them and pick the one that sounds better. Unfortunately, I nor anyone else can tell you what sounds good to you.
Bob Johann
SoundQ SVT
1998 T-Red SVT Contour #3088
2001 IASCA Pro Street 1-600 Champion
2002 SLAP Pro Street 1-600 Champion
2002 MECA SQL Master Class Champion
2003 IASCA StreetX 1-600 Champion
2005 SLAP Expert Street Champion
Posts: 133 |
Originally posted by platinum_drew: if they're getting 1250 watts, and the 15" only handles 1000 RMS, when you really crank it you'll get some distortion and will probably damage the sub. if you want more "boom", smaller subs tend to have a tighter, punchier bass. bigger subs tend to be able to handle lower frequencies and the bass carries better, but my vote would go for the 12"s
Thanks
Originally posted by hmouta: u could build a bandpass box for the 12s to get it boomy. gotta guess a bandpass for a 15 will be huge. thats alot of power. r u sure u really need all that? or do u just want to be able to tell people that your system is 4million watts. is your front stage getting lots of power too? that might be way out of balance if the front is getting very little power.
I have a 650.4 amp for the doors and plan to put components
Originally posted by SoundQ SVT: How about this.... pick the speakers that sound the best to you.
I haven't seen any of these speakers in any stores out here. I actually own one 12" Solo X and it sounds crazy. I doubt if I would find a 15" L7 in a store display in my area. My question is since it's only getting half of it's RMS, is it worth even bothering with them as opposed to some subs that I can achieve max RMS? Kind of like how the CSVT really moves at 4000RPM as opposed to trying to get somewhere at 2000RPM...
Posts: 259 |
get the 12's...one they will save more space, and once u amp them, they should hit harder!
98.5 Black Contour SVT #5959
Posts: 133 |
Originally posted by BigBEN: get the 12's...one they will save more space, and once u amp them, they should hit harder!
I think that's where i'm leaning...
Still I am trying to find out. What is more optimal? A sub that can recieve much more power but is only recieving 1/2 of it's rms or a sub that cannot recieve as much power but is at it's full rms? Of course the 12" is this super spl sub but I'm just playing music and not competing....
I don't even know how I would fit the 15's in my trunk
Posts: 1,231 |
you know what, go with 2 10 inch subs. I find my 2 12 inch subs are way more overkill than i need for the car. Just my two cents, If I ever buy new subs agaun I will be going that route.
95 Merc Stique
Zetec 2.0 Auto
Posts: 133 |
Originally posted by loggerbomb: you know what, go with 2 10 inch subs. I find my 2 12 inch subs are way more overkill than i need for the car. Just my two cents, If I ever buy new subs agaun I will be going that route.
Overkill as in too much bass or as not really hearing a major difference?
Posts: 610 |
2002 Cougar
2.5 duratec/ mtx-75
85,0000
Mondeo ST-200 wheels/BFG KDW NT
black/black
Spec Stage 1
Torsen T-2
Trubendz 2.5 flowmaster dual exaust
apexi s-afc II
K&N FIPK
