Seeing that I was the first here in the CEG to do this I feel the need to speak on this
The above car used to be mine (duh
) and here's what you've gotta do:
-you need the tails AND the center reflector because of the chrome strip that runs all the way across it.
-the bulb connector is slightly different and because I was lazy at the time all I had to do was use some duct tape to hold the assembly in place (everything could use some duct tape now and then
) and besides, the big plastic piece holds everything in place and its then hidden. Some good with splicing will do it the right way though
I feel this was a great mod because it got rid of the chrome that a car with a Euro look doesn't need and to help that along further I used blackout tape from PepBoys to eliminate all the chrome from the rear section, even the emblem came out eventually and custom decal installed in place of the Merc logo
Additionally the area around the licence plate looks 1000% better IMO and the backup light area looks custom with the black lines in there. In closing this was one of my best mods not only for the above reason but it was also free because someone else wanted what I had, perfect! Good luck doing this and if you need further proof, refer to the above pic
