Posts: 4,476 |
ok - so the Edelbrock RPM 5503 does NOT work on an SVT, the size of the muffler is perfect, but it requires an offset/offset config, the 5503 is a center/offset setup - so it doesn't work...  i did a return and now have the Edelbrock 5542 (which is their only 2.25" offset/offset setup) but the muffler is WIDER and SHORTER than the 5503...  trying to be a pioneer, but it's costing me $$ - so far i've spent $95 on the 5503, $16 on returning it, and another $20 getting the 5542... is the 5542 going to fit, or should i just sell the sucker!
Todd Christ SVT Contour Registry MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator '98 E0 SVT Contour #1037 of 6535
Posts: 316 |
I bought a Dynomax Ultraflo 6" round muffler for $69.95 model 17230 i believe from Summitracing for the resonator. I had drone/rasp before, now it in gone.
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
Posts: 1,181 |
Save the trouble. Buy a magnaflow.
98 Merc. Mystique LS
Red Wings and US Soccer 0wn j00!
Posts: 407 |
Ditto here. The 5x8 fits perfectly and sounds sooo nice.
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
Posts: 316 |
Posts: 4,476 |
Originally posted by HoosierContour: Summit
 that's 2.5"!!!
Posts: 316 |
If you are going to do it, do it right, go 2.5" custom catback. :p
Posts: 4,476 |
ok - so anyways... for those of you who don't read, i already have this part in my hands...
bang for the buck folks... :rolleyes:
Posts: 4,476 |
so how "wide" can the muffler be under there? (going back to my original query)
Posts: 105 |
I did some measuremnts and it seemed a 6 in Diameter resonator would hang to low. How low does it hang and have you bottomed out on anything. Does any one have a suggestion for a good resonator that will bring my exhaust close to stock loudness. I have a modified y with a cat so it looks like a sho shop with cat. Sounds good but just to loud right now.
Green 2000 SVT #1166 mods-K&N open air filter & Custom heat shield, Custom y pipe and 30 in resonator,DMD, arm rest heightened http://www.geocities.com/savinoss/Cars.html other cars-89 sable 197000 miles and still going-Wifes car 99 Mystique V6 5 spd
