Posts: 138 |
I was thinking of getting some of this form Summit and wraping my off-road Y-pipe and my Exaust manifolds after I gut my pre-cats. This would cut down on heat under the hood and the transfer of heat to the oil pan down there correct?? Also why does this void most header warrentys? Has anyone done this to reduce heat, is it worth it?
1998.5 Brullen SVT
Posts: 2,112 |
header wrap tends to heat-stress the metal, causing cracks and such. I wouldn't do it, I don't think it's really designed for a daily road vehicles (versus something race-built).
Posts: 1,028 |
Plus, the wrap didn't help keep the y-pipe temp down, or the oil temps down for that matter. There was a discussion not too long ago about this...
Chris NJ 98.5 SVT Silver Frost w/Frankentrans carsla AT optonline DOT net
Posts: 138 |
What can you do then?? Can I make a heat shield to deflect heat away from my oil pan. Hot oil, Hot engine, Boom!!!, no more engine.
Posts: 3,419 |
Oil cooler. Near the top of my "want" list (like #2). Slowly working it's way over to my "need" list. Of course, the need list is pretty empty because the need budget is shot.
And something better than the SVT cooler, as well.
Posts: 3,248 |
Thermo-tec also makes an aluminum insulated "heat shield material with sticky back. I have some for application to underside of my UIM and was going to apply to oil pan facing Y-pipe. If sticky does not hold was thinking of large stainless clamps or wire oto hold it. i'll let you know..
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 1,028 |
Originally posted by PA 3L SVT: Oil cooler. Near the top of my "want" list (like #2). Slowly working it's way over to my "need" list. Of course, the need list is pretty empty because the need budget is shot.
And something better than the SVT cooler, as well. The oil cooler does work. The air to oil rad lowers the temps by a good 30-50 degrees.
Posts: 1,181 |
Ive seen no change in driveability after installing my y-pipe (no oil cooler either). Even after 3 hr trips, the engine runs as smooth as startup. Just my experience...
98 Merc. Mystique LS
Red Wings and US Soccer 0wn j00!
Posts: 1,028 |
Originally posted by Antiramie: Ive seen no change in driveability after installing my y-pipe (no oil cooler either). Even after 3 hr trips, the engine runs as smooth as startup. Just my experience... I didn't see anything either, but the guages don't lie. Whenever I had some fun, the oil tmep shot up and over the 250 degree (F) dial. Once I would let go, the temp would drop, very slowly, to about 220, and this was this winter. I found out the stock y-pipe has insualtion on it, for just this problem. It was recommended to me to get an additional oil cooler installed to remedy this, which it has. Or, you could always get an exhaust shop to take apart your stock y-pipe and somehow attach the insulation to your new y-pipe.
Posts: 149 |
I have the off-road Y-Pipe........ and I've read much about higher temps........
Basically, where can I get the least expensive OIL cooler for my 98 SVT?
