Posts: 785 |
i was wondering exactly how much oil should i put, i know people around here recommend 6 quarts... but just to be sure now i have the escape baffled oil pan so should i still put 6 quart ?
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
RU-3530/CTA Intake Pipe
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
SPEC Stage one/Spec Alum. Flywheel
HERE
Posts: 853 |
Originally posted by SVT3Rivieres: i was wondering exactly how much oil should i put, i know people around here recommend 6 quarts... but just to be sure now i have the escape baffled oil pan so should i still put 6 quart ?
Ford says 6 quarts, people recommend 6.5 quarts.
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998
WR Headers GMK CAI
Blaupunkt system fiberglass tweeter pods
L.E.D. tail lights in the works
Posts: 217 |
I put 6.5 in every time. Never had my oil light come on around hard corners.
2000 svt contour
1996 oldsmobile eighty-eight
Posts: 853 |
I have never had the light either, but does it even come on before the engine spins a bearing?
WR Headers GMK CAI
Posts: 785 |
but my question was more if it make a difference with the escape oil pan ?
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
Posts: 702 |
Originally posted by SVT3Rivieres: but my question was more if it make a difference with the escape oil pan ?
No it shouldn't. The escape pan just has a better baffling system to keep the oil closer to the pickup tube. That is also what the windage tray is designed to do: Keep the oil near the pickup during drip back and reduce aeration of the oil. I say add 6-6.5 quarts still. The oil problem still exists due to the heads not having a decent amount of oil drainback, so the added oil will definitely benefit you.
CSVT E0 3L
14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
Posts: 22 |
keep enough oil in it and you will be fine. An oil light will not come on before spinning a bearing. It is just something that happens over time from oil starvation. Ford calls for 5.5 quarts. I would at least put in 6 quarts.
1998 red CSVT
02' 3l hybrid swap, MSDS headers, KKM intake, UD pulleys, Brenspeed tune, DMD
poly mounts
Posts: 4,693 |
The specs on my Escape is 5.5 quarts. I use 6.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 504 |
ya I usually put 6 litres of mobil 1 5w20 in there, I buy the 5L jug (it's $29.99 @ wal-mart) + 1 litre of Lucas Oil Stabilizer  . Runs well.
1998 Mercury Mystique LS
- Looking for SVT EXHAUST, SVT Rear bumper (silver frost) and ANY rocker mouldings (side skirts)
Posts: 1,049 |
ive used 6 quarts for the past 4 3 years in my tour. i always get the 5 quart jug at walmart wich is like $20 at my local walmart plus a extra bottle. i run the k&n oil filter.
