Try a search for "resistor" in the performance forum. This has been discussed quite a bit. A single resistor in series with the sensor will effectively fool the computer into thinking the intake air is cooler. Just cut one of the wires going to the sensor, and splice in a 1/2W resistor. You'll want between 2 & 10K ohms of resistance. Put some push connectors on the wires so you can experiment with different resistor sizes and see what happens. Some say it helps, others say it aggravates pinging.
