#121050 07/09/02 06:01 PM
jiako Offline OP
I had it up on the lift today and we were looking for a leak or something of the sort...but the sound seemded like is was coming from the x-pipe. I was wondering if anyone else was having the same problem
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill|
Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
i have had 0 problems with my exhaust.. not sure whats going on with yours..?
95 SE Champagne Mettalic
True Dual exhaust with X pipe and Redline mufflers
KKM Tru Rev intake
H&R Springs/KYB struts
Apex-i S-AFC
65mm Throttle Body
17" Ace Spades
4 Pt Racing Harness
Window Tint all around
New Engine @ 117k kilometers
G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass"
quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
jiako Offline OP
did you locate your x-pipe or did u just throughh it in. i may just be paranoid..ill see at the dyno on sat
N
N
Where did you guys get your X-pipe?? Is it a direct fit?? I don't have alot of experiance with tours. I was a mustang man. Luved the sound of an x pipe on a stang.
thanks
ryan confused
mine WAS just thrown in, but its right where the cat used to be, ill try and get some pics up for you
KKM Tru Rev intake
Apex-i S-AFC
65mm Throttle Body
17" Ace Spades
4 Pt Racing Harness
Search my member # (993) for broken coaches whistle. I hate my true dual set-up... frown
Mark
