Posts: 13 |
Please help? This is an open question to anyone who already has MSDS headers installed.
Has anyone passed any state emissions test that has been tested with the MSDS headers installed?
Primarily I'm interested in PA emissions, but any info will be a help.
Thanks!
Dave Ford
Posts: 3,419 |
Here's my take: 1) You have to get someone to inspect that is willing to "overlook" the fact that you removed two catalytic converters. No cats, no sticker. You won't even get to the sniffer if that's noticed. 2) IIRC, the precats are there mostly for cold start emissions control. The main underbody cat is what cleans the exhaust mostly when the car is at operating temperature. So, just make sure the car is tested hot, or gets driven in a spirited manner for 5 - 10 minutes before it gets smogged for cleanest results. 3) Plenty of people have passed smog tests with the "mystery mod", but I don't know that any were on the "loaded test" we have. Most likely they were idle tests. However, unless you are in the following counties, you won't need the smog test anway: (Southeast) Bucks, Chester, Delaware, Montgomery (me), Philadelphia, (Southwest) Allegheny, Beaver, Washington, Westmoreland. Oh look, I just realized that the chassis dyno test is only for the SE counties, and the SW area gets idle tests. Lucky me. Looks to me that Warwick isn't in any of those counties, so you're off the hook. Caveat: Make sure you have functioning MIL eliminators. In the future, a larger part of the SE area (probably you included) will be required to go through an OBD-II test. Basically, if you have any CEL codes or incomplete monitors you'll fail the emissions part of the test. It's only a pilot for now, but it's meant to replace the smog test for 96+ cars at some point in the future. Check it out: http://www.drivecleanpa.state.pa.us/
Posts: 13 |
Thanks, unfortunately I'm in Bucks County, Warwick Twnsp, not Warwick in central PA.
Your info is very revealing and appreciated.
It doesn't look good for the headers.
Posts: 136 |
When I had my old Merkur, I took the cat out... and it still passed our emissions test...just to prove that our clean air rules are just another tax grab up here....That's with the guys actually looking under the car with those fancy mirrors... I have 20 months before I find out what happens with my MSDS headers on the car.....always make sure the car has been running at temperature for awhile before the inspection...and try some clean gas ...we have 94 octance with 10% ethanol up here in BC.
1999 Black SVT #2639/2760 on 08/11/1999; w/18" OZ Racing Superleggera's, Yoko Paradas. MSDS Headers,Quaife LSD, Borla,KKM,chipped,DMD,Baer 13" Track rotors. Lowered/HR and Koni's; HPP RSB
Posts: 153 |
If you don't get caught on the visual you will pass with flying colors. "Somebody" I know passed the CA dyno emmisions test (15 and 40 mph) with no main cat. HC were up, but still like 20% below the failing limit. (FWIW, even though the car passed it was putting out avg. emmisions comparable to the 1977 vintage average.)
That car now has a new main cat with just the pre cats done, mainly to be kinder to the environment.
97 SE MTX, KKM, UR UDP, 19# Injectors, SVT TB, SVT UIM, SVT Flywheel, Grizzly Street Clutch, Upgraded motor mounts, mystifed precats, brand new main cat, SVT exhaust sans resonator, 205-55-15 Dunlop SP5000's 154hp / 156 tq before the SVT exhaust, SVT dual honed upper and swapping the mystery main cat for mystery precats. My Profile
Posts: 1,028 |
Originally posted by David Ford: Thanks, unfortunately I'm in Bucks County, Warwick Twnsp, not Warwick in central PA.
It doesn't look good for the headers. You will pass, I recently (Jan 2002) passed NJ emissions with my headers. The car hadn't properly warmed up and it still passed on the 25mph rollers. No problems, and the guys there were excited to 'drive' my SVT. :rolleyes:
Chris NJ 98.5 SVT Silver Frost w/Frankentrans carsla AT optonline DOT net
Posts: 331 |
some good, and inspiring, info here...anyone have New York experience or advice?
[[Justin]] '98 Silver Frost SVT #2089/6535 I am made of cheese My car is in the shop When I drop the clutch, I get wheel hop Do not eat me, oh please
Posts: 5,296 |
I know in most of upstate NY, they only have visual inspection. But then again, I know a guy who will pass me with open headers and no pipe.
Posts: 1,537 |
Westcheter requires the treadmill test. In order to do the treadmill test, the engine has to be running at least 20 minutes prior to tread mill test.
Unless the guy doing the test is a real pr*ck, you should pass without any problems.
I'm going in for my inspection in January, and I want to hear what they have to say about the SVT Exhaust.
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Posts: 3,419 |
Originally posted by David Ford: It doesn't look good for the headers. This is why my "wish list" doesn't include headers (when I get some real $$$ again). Now, if I move to Michigan ...
