Posts: 21,197 |
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 9,065 |
Originally posted by 96BlackSE: Just a couple of things if anyone is going to be using a similar setup, its not possible to use the ST220 LIM unless you use the ST220 fuel rail since there is a difference on how they hold the injectors in place... But it is possible to mount the ST220 manifold to the plastic LIM...
But now...are u going to have any hood clearance issues, because I know the St220 manifold sits higher and the LIM sits lower.
I have had the pleasure of actually holding and finger banging an st220 manifold.
Posts: 1,210 |
Seems like there are no hood clearence issues as of now I'll now exactly when the hood is bolted on but I doubt it
The St220 LIM is the same height as the plastic LIM when I checked
3.0 14.392@97.237 2.302 60ft
OEM 4-bolt LCA's $105 each
Watch me go
Posts: 130 |
My hood vibrates on the Oil Fill Cap on the front valve cover. I have a 99 cougar, but you may run into the same issue. Im using the 3.0 front valve cover temporarily, so I'm not concerned about it. It is really annoying though.
Looks good btw. Did you paint the UIM, polished, or just stock?
Posts: 1,210 |
The uim is jet hot coated
Watch me go
Posts: 1,210 |
I just started her up two minutes ago  I missed the noise it made  Now time to put on the serpentine belt and exhaust and I can take it for a spin
Watch me go
Posts: 21,197 |
Originally posted by 96BlackSE: Now time to put on the serpentine belt
-'96 SE MTX 3L
Posts: 310 |
why the long face? The serp belt isn't necessary to just start it up for a sec to hear it run. No major items driven off the belt anyway.
I'll put holes in him!!
