#120853 07/07/02 01:52 AM
Griffin Offline OP
hey i just had my resonator removed and had straight pipe put back in. I dont like the raspy , and rattleing noise it makes . I was wondering what I should replace the pipe with AGAIN, to get a great deep throaty sound. Thanks alto , please respond
#120854 07/07/02 03:01 AM
i have a 98 tour svt and i did the samething and i found that there is a few companies that make a high flow resinator that will improve the souund but remain with the output of the straight pipe.
#120855 07/07/02 03:05 AM
like who?
Ryan "Bigg Daddy" O.
#120856 07/07/02 04:08 AM
Edelbrock smile
I should finally have my RPM 5542 in my SVT this week laugh
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
#120857 07/07/02 01:08 PM
I have your answer. I don't know if you have been reading my posts, I have made some serious exhaust mods recently to my stock system.
The resonator that you removed is not a true resonator. If it were, it would be of a tubular design. It a two chamber muffler placed in the center of the exhaust system to take the raspy sound out of the exhaust note. Never remove the center muffler. Replace it with a tubular bullet style muffler or a glasspack. I replaced my "resonator" with a bullet style turbo muffler and it sounded deep. However, I went a step further on Friday and has the puny rear muffler hacked off as well and then had a pacesetter dual chrome tip with built-in resonator added on the end of the pipe. It's not too loud although it doesn't sound as deep as a V8 would. It does however sound awesome at WOT and is a little quicker now.
2000 Stique
2.5 Duratec
Modified Ehaust
Fast with class!!!!
#120858 07/07/02 01:53 PM
Y
Y
Griffin - you can replace your straight pipe with a glasspack muffler . It makes all the difference in the world . Mine has a nice low growl at idle & a throaty acceleration note with NO drone at cruising speed , and NO rasp whatsoever . Make sure you get a "straight-through" glasspack (i.e. - NO BAFFLES) . The one hanging under MY car is a 2.25" I.D. inlet & outlet , no offset glasspack that's about 23" long . I just measured it for another CEGer 2 days ago , that's the only reason I have the numbers right here wink . Mine is welded to the stock exhaust , but I'd imagine it could be clamped if you wanna go that route . You'll like the sound with the glasspack in there .
~~~~~~~~~~~~~~~Allen
********** Love Those REDWINGS !!! **********
2000 Contour SVT Black w/ Tan #2137 of 2150 / built 2-4-00
Mods : ~ Factory DRL mod ~ "Powered by Ford" seatbelt covers
~ OF's TH fix ~ Audi A-6 Side Repeaters ~ Highs in Lows Mod
~ #885 foggies ~ KKM filter ~ Mondeo ST200 Badging & Shiftknob
~ Pre-98 Sails ~ Nose Bra ~ Trunk cargo net ~ '98 Clock
~ "Glasspacked" Resonator ~ Painted Rear Reflector
~ Räzo Pedals ~ Custom "Mondeo" Windscreen Banner ~ Ventvisors
~ Lighted Moonroof Switch ~ Mystique Rear Seat Light
~ Painted Grille Ring ~ H&R Springs & Mondeo ST200 Struts
~ Mille Miglia "Cello" Wheels
My old 95 \'Tour SE ~ New SVT pics here
#120859 07/07/02 02:04 PM
You are all assuming that this guy has an SVT like the rest of you. If you have a stock Tour' or Stique' and just replace the res. the system will not be very deep at all. The stock rear muffler on a standard Tour'will tame the exhaust note considerably even with a glasspack.
......Doogie61
#120860 07/07/02 07:01 PM
just a few questions about exhaust. So replacing the resonator with a glasspack is the way to go, and also replacing the y pipe , right. What would be the best glasspack to get, from which manufacturer? And is the SHO shop y-pipe better than the BAT one or are they about the same. What other things could be done to keep the deep sound and not sound ricey. Thanks..
2000 SVT-Black-
SHO CAI
SHO Front tower brace
super white lights
yellow fogs
limo tint all around
#120861 07/07/02 09:32 PM
Griffin Offline OP
hey thanks alot . I had the resonator removed and replaced with straight pipe , and they had to bend it to make it fit , can they do that with the glass pack pipe too. What company , and size and model should i get . How much do they cost, and how much should it cost to replace. Thanks alot guys
#120862 07/08/02 06:27 AM
what they will prolly do is angle the glasspack like they did mine- send me a pm if you would like some pictures e-mailed to youof my set up on a 99se. Single exhaust- glasspack in resspot, really nicetip in rear- no rear muffler. sounds nice- at least i think so- some of the folks at the national meetmay have heard my car- for the little $$i spent i loveit- going with a full pipe replacement and magnaflows when money allows- i just haven't heard anything that beats that magnaflow sound
99 SE Sport 2.5 Duratec
Spruce Green Metallic..
Aesthetic Only.... For Now
...the closest I will ever get to having a Turbo will be the Gillete Mach 3 variety!!!
