Posts: 4,270 |
Originally posted by Y2KSVT: Is that blower going onto your stock block? Wasn't it running a little rough at SZ06?
Mark
everything is being dealt with don't worry.
The stock block can take up to about 450hp, i don't plan to be anywhere near that high so i'm not too worried about it.
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
2000 Green CSVT gone on 2/17/06
2001 Toyota Corolla (SHE RUNS!!!)
1989 Mustang LX 5.0
Posts: 10,015 |
Sure should fly after your done. What song we you like me to sing acapella at your funeral "Dust in the wind"?
You're my boy yellow!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 259 |
DAMN! your car is gonna HAUL!!!
have fun with it!
98.5 Black Contour SVT #5959
Posts: 6,106 |
Originally posted by The Five-Oh!: Originally posted by Y2KSVT: Is that blower going onto your stock block? Wasn't it running a little rough at SZ06?
Mark
Oh I'm not worried, it's not my car.
I'm fully aware of what a stock 5.0 block can handle. At SZ, I just wasn't sure if YOUR block could handle that. Good to see the motor will be fresh though. Good luck with the install!
Mark
2000 Black CSVT
Posts: 4,270 |
it'll be fine, i hope. once i get this stuff done i'll probably start saving up for a full motor build.
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
1989 Mustang LX 5.0
Posts: 60 |
Actually many are getting closer to 550-600 rwhp on the stock bottom end. What you need to watch out for with the boost is the blown HG. I am currently running 15 psi on a mostly stock bottom end, but with arp studs and I am just lifting the heads. I don't have actual numbers, but based on traps and weights I'm in the 450-475 rwhp range. I'll find out later in the week when it finally gets tuned. what size injector are you running? Good luck with the C&L meter, it's either hit or miss with them. My car ran terrible with the C&L, I switched to a FRPP and the car ran like stock, night and day. How much boost you running?
00 SVT #985
Silver Frost
89 Mustang GT TT
-410.6hp/460.7trq (couldnt pull past 5k-lean)
12.77 @106 Before turbos, 12.82 @120.12 With them
-95 Contour GL, 140K FREE!
-WPI FSAE 05'-06', build a race car, get school credit
Posts: 4,270 |
Originally posted by turbo_fox: Actually many are getting closer to 550-600 rwhp on the stock bottom end. What you need to watch out for with the boost is the blown HG. I am currently running 15 psi on a mostly stock bottom end, but with arp studs and I am just lifting the heads. I don't have actual numbers, but based on traps and weights I'm in the 450-475 rwhp range. I'll find out later in the week when it finally gets tuned. what size injector are you running? Good luck with the C&L meter, it's either hit or miss with them. My car ran terrible with the C&L, I switched to a FRPP and the car ran like stock, night and day. How much boost you running?
the pulley on there is good for 9-10psi, i also have a higher boost pulley and belt but won't use that anytime soon. i planned to use 30# injectors, i'm hoping the C&L works out.
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
1989 Mustang LX 5.0
Posts: 1,610 |
Posts: 1,651 |
Lookin ggood alex.. lots hawt. I am jealous....
I reject your reality and substitute my own.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Looks like some fun indeed!
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
