Posts: 130 |
My power antenna went. It's stuck in the "up" position. When I turn the car off, you can hear the motor run for about 30 seconds, but the antenna doesn't move. Anyone got a working one, or going to a junkyard and might be able to grab one for me?
1998.5 SVT Contour - Black
H&R's
Optimized Y-pipe and TB
Open element intake w/heat shield
18x8 Mas Italy Axels (40 offset) w/225/40/18
2x Kicker 8" midbass "subs" in rear deck (infinite baffle setup)
A few more little things...(like bushings)
Posts: 785 |
its happen to me once.. i push it in as the same time the engine and i worked perfectly since... maybe i got lucky
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
RU-3530/CTA Intake Pipe
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
SPEC Stage one/Spec Alum. Flywheel
HERE
Posts: 1,399 |
I bought one of the kits off e-bay. Worked like a charm, and wasn't expensive.
98 Silver Frost SVT
97 BMW 540I Sport, six speed
"Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future"
"A coveted car should never stunt your life, but should make it more rich and interesting."
Posts: 504 |
Originally posted by Phil Rohtla: I bought one of the kits off e-bay. Worked like a charm, and wasn't expensive.
+1, very inexpensive and just feed the cable until the motor catches it. If you have an aftermarkt player with remote, you don't need anyone else to help you install it.
1998 Mercury Mystique LS
- Looking for SVT EXHAUST, SVT Rear bumper (silver frost) and ANY rocker mouldings (side skirts)
Posts: 130 |
Thanks, guys, I'll check it out.
H&R's
Posts: 504 |
Originally posted by LegacySHO: Thanks, guys, I'll check it out.
Good, if you go eBay or even flee market, you're going ot pay under $20 for the whole thing so it's worth it. Plus it's better than your old power antenna because this one retracts COMPLETELY as opposed to leaving about 30cm sticking out. And it's a new chrome finish so it adds a nice touch. If you go with ebay, it takes about a week to ship so be patient and play lots of CDS
