Posts: 323 |
I took off the throttle body yesterday for cleaning...no problems. I looked down the accordian tube between the TB and MAF and saw this little sensor that plugged into a 2-wire connector outside. The business-end of the sensor in the accordian tube was noticably coated with a black substance. Is this protective coating from the factory or is it junk that I should clean off?
'98 SVT KKM / TH fix / Mobil 1 / Synth tranny cocktail / JVC LX-30 HU / 10" JL sub / Alpine V12 amp / Panther 199 wheels / Kuhmo Ecsta 215/45/17 / Bosch +4 / Ford Motorsport wires
Posts: 1,244 |
I believe you are talking about the IAT, correct?
For everyone, can this be causing me to throw a CEL?
Posts: 4,899 |
Just get some electronics part cleaner and spray it on there, that should clean it. Do not touch it with your hands, that sensor is $$$.
Posts: 620 |
Originally posted by Patrick: Is this protective coating from the factory or is it junk that I should clean off? Clean it!
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
