#120675 06/29/02 02:05 AM
N
No_Cure Offline OP
N
has anyone seen the new JET performance products Power Control Unit? I saw it in the Jegs catalog.
they list it for the 2.5 Mystique. After going to The Jet website I could nt find the product. But they have a list of products under ECU upgrades and the 2.5 contour is there. After calling them(JET) it will work on All Duratec ( except SVT ) The unit remaps fuel curves and ignition timing.
Except it does nothing for the Auto tranny. I had them fax me the instructions. Its got a wiring harness that plugs into the Throttle Postioning Sensor and Mass Airflow Meter. The Unit can be used with ANY aftermarket airflow meter or throttle body? Go take a look and tell me what you think. Jegs wants $199 for them. IS there already something out there like this?
It sounds jus like I "CHIP" except you do not get the auto tranny stuff. And I doubt it will remove the rev limiter. The website says you will get 12-13 HP. The Tech I talked with said more like 9-11 Hp at the wheels. Which really means......5HP peak hp at the wheels. I wouldn't mind trying it , but I have an Auto tranny. And would like firmer shifting. But I don't really care about the rev limiter.
Its not what You buy,
Its what You build!
98 Mercury Mystique 2.5 Duratec( my wife's car)
87 Toyota Supra Turbo
475Hp at the rearwheels( my car )
Previous Jet products, IIRC, were only for WOT, and therefore inferior to Superchips/Diablo.
Is this a new product?
Let me put it this way. I wouldn't want to be the guinea pig, when for a few bucks more, you can have a proven chip that does everything you want.
JMHO.
"Function before fashion."
'96 Contour SE
N
No_Cure Offline OP
N
that was kinda my thoughts as well.
The Tech said it worked thrugh out the entire powerband. But I have heard alot of bad info about JET also.
Its what You build!
