Posts: 190 |
Well my battery has been drained the last two nights in a row. I think that I have found the problem...
Well, it seems as though all the door switches stay lit up constantly. Even when the car is turned off and the lights are off and the car is locked. I know that these switches draw small amounts of power, but I drained the battery the first time with my subs running with the car off. I have not charged the battery since then, but only jumped it and let it run for a few minutes. Since the car sits (because of other problems) it seems as though these switches are draining the little bit that is left in the battery. Does this make any sense?
1998 Silver Frost CSVT
#4427 of 6535
Born January 15, 1998
AIM: cannondale828
Posts: 5,143 |
um... how old is the battery? It sounds a lot like the battery was on its last leg, you killed it by running your stereo WITHOUT the engine running, and it wont hold a charge anymore... When my battery went I could jump start the car and run it fine and restart it again if I tried within the hour. but any longer the battery would be right back to dead again...
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 190 |
Yeah that makes perfect sense. But what about the door switches?
#4427 of 6535
AIM: cannondale828
Posts: 853 |
Have you replaced the leds in them or had them out of the car.
When I changed leds colors in mine I took the two front doors apart and I must have switched the drivers from passengers, because they stayed lit when the key was not in the car. I switched them around and all was better.
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998
WR Headers GMK CAI
Blaupunkt system fiberglass tweeter pods
L.E.D. tail lights in the works
Posts: 190 |
No, I haven't. My window switches on the driver's side don't even work.
#4427 of 6535
AIM: cannondale828
Posts: 190 |
Does anyone have any ideas?
#4427 of 6535
AIM: cannondale828
Posts: 190 |
Does anyone (like Tony2005) think that the door switch lights being on and the "deiseling" could be directly related to a bad ignition swtich?
#4427 of 6535
AIM: cannondale828
Posts: 190 |
No, I do not have a Ford CD. I do not even know where to start with the wiring diagram.
Do you think it is worth it to go ahead and change the ignition switch?
#4427 of 6535
AIM: cannondale828
Posts: 5,345 |
PM todras to get a Ford CD.
http://www.contour.org/ubbthreads/showprofile.php?Cat=&User=1049&Number=1282832&Board=trouble&what=showflat&page=&view=&sb=5&o=&fpart=1&vc=1
What are you going to do if you change the ignition switch and it does not fix the problem? If everything points towards that, then yes, but at this point you are just shooting in the dark.
Actually, if it were me, I would just disconnect the wiring to the light on the door switches and see if the problem is gone (Try Fuse 34 for courtesy lights). Better to not be able to see the door lock lights than have a dead battery.
Also check the Central Timer on the Passenger Compartment Fuse box under dash, left of steering column.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1051299&Forum=trouble&Words=central%20timer&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=1year&Main=1050786&Search=true#Post1051299
Central Timer location, 2nd picture, retangular looking box on Fuse Box, right of his left thumb.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1056473&fpart=1&PHPSESSID=
Fuse diagram
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=887004&Forum=trouble&Words=brake%20lights%20fuse&Match=And&Searchpage=0&Limit=25&Old=6months&Main=886893&Search=true#Post887004
1996 V6 ATX 96K miles
