Posts: 1,384 |
Valvoline puts a promotion out every now and then for their Maxlife oil, and I'm sure some of you guys can use this. I did this promotion when they ran it a few months ago, and received the rebate check w/o any issues. Furthermore, if you have a Walmart around you, I found that this was the cheapest place to buy oil, since most of us will be needing the extra qt. Here's the link: http://www.valvoline.com/maxlife/microsite.aspHope this can helps a few people out.
99 Black Contour SE Sport
Posts: 5,345 |
You are  . Thanks.
1996 V6 ATX 96K miles
Posts: 1,986 |
Originally posted by ancientsanskrit: if you have a Walmart around you
What is this Wal-Mart you speak of?
Suck it Trebek! And by Trebek I mean Seaegee!
Posts: 5,882 |
Originally posted by Ã?Å?ber Evil Mushu!: Originally posted by ancientsanskrit: if you have a Walmart around you
its a place where they sell wall stuff.
Posts: 3,816 |
Originally posted by svtizzle4stizzle: Originally posted by Ã?Å?ber Evil Mushu!: Originally posted by ancientsanskrit: if you have a Walmart around you
Posts: 6,910 |
i wouldn't use the max life stuff all the time, I started using it in my zetec because of high miles and the always present slight leak at the trans, anyway after about 5 oil changes with the max life oil I got a worse leak, think it is the rear main seal, it has slowed back down now that I have gone back to regular oil, so used be ware ...
- 95 Mystique LS - Zetec/5spd
Posts: 3,709 |
Originally posted by Tony2005: You are . Thanks.
Originally posted by Chickens: Religion can't do much for ashholes (unless you are an alterboy)
98.5 Se w/SVT mods
98 E0 SVT~ sold
Posts: 6,791 |
Hmm, I use this oil... And have been using it for quite some time. Are you claiming that by using it, I will develop leaks?
Posts: 6,910 |
Originally posted by BatteryLight: Hmm, I use this oil... And have been using it for quite some time. Are you claiming that by using it, I will develop leaks?
maybe maybe not, just saying what happened to me, but then again I already had an issue, it got better and then worse ...
you deside, if you are not having any issues then you should be fine
Posts: 3,193 |
I don't see much of a reason for it unless you have some leaking issues. I never used it, even at 180,000 miles.
Why can't they make these offers on something I use, like VR Racing?
Brad "Diva": 2004 Mazda 6s 5-door, Volcanic Red
Rex: 1988 Mazda RX-7 Vert, Harbor Blue.
