Posts: 44 |
which chip should i use on my 1996 contour lx, v6 ATX. computer code grz4
thanks
1996 Contour LX ATX V6 Ford 9mm blue wires--Bosch platnum +2 plugs-kkm intake--SVT throttle body--Superchip(on the way)--20% tint--side markerlights--Badgeless
Kenwood Cd Deck--MTX mono amp--MTX 15" Thunder 8000(soon)
Posts: 231 |
I have a 96SE 2.5L (ECM Code XXY7) I went with the SuperChip. It gave a noticeable difference in the mid to upper RPMs, as well as removed the speedlimiter (which was my main reason for getting it.) From everything that's been said in the past, the Diablo doesn't guarantee removal of the speedlimiter.
Best bet for reference, search the forums for Superchip AND Diablo. You'll come up with plenty of reading...
I love my Contour to death, but my 'vette is still my #1 baby. There's money to be made in racing. I should know. I put a lot of it there. You can make a small fortune in racing. Start with a large one. How fast do you want to go...how much money do you have? You can fix a lot of things, but you can't fix stupid!
Posts: 816 |
If u get custom programmed Diablo $350 I bet it will remove the limiters if you tell them to.
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 491 |
Go Superchips. Better percentage of happy customers here. Trying searching for you computer code and see if anybody else has any experience with it.
1997 GL Sport MTX, Soon to be the fastest proven Zetec around.
Posts: 955 |
im sure this has been ask for b4, but since were on the topic here, how would 1 figure out the computer code?
Experience is the worst teacher; it gives the test before presenting the lesson. "You peel my onion down to the nun" - Gene Hackman [Under Suspicion] -Walter- 96 Contour LX
Posts: 13 |
Superchip my friend...can't beat it.
1998 Silver SVT-KKM Cold Air Induction, Eibach, Koni, Custom Exhaust (2.5 SS I/D) w/ Pilot Motorsports Tips PM-576 4" O/D,SuperChip, A/R Rims w/ 225/50 ZR Potenzas
Posts: 491 |
Originally posted by NITROS: im sure this has been ask for b4, but since were on the topic here, how would 1 figure out the computer code? The computer is located in the passenger compartment, on the passenger side, behind the glove box. There is a white clip held onto the computer by a single not. The computer code is located on behind the white plastic clip. somebody posted a picture not too long ago.
Posts: 620 |
Among those who have really eyeballed both, it sounds like most lean toward the Diablo.
There's apparently another chip now: Kenne Bell. This one comes with a switch so you can choose between two different programs, someone said. I hope someone finds out more about it. And there's another chip called Jet something. But I'm not sure if these are available for duratec.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 3,421 |
Originally posted by NITROS: im sure this has been ask for b4, but since were on the topic here, how would 1 figure out the computer code? walter if you cant find it let me know and ill stop by one day. cougarboy1989 Im real happy with my Superchip. i dynoed an extra 10hp from just chip
Posts: 163 |
I bought a Superchip and dynoed it in my 98 SVT and LOST 4 HP. I sent it back, they reprogrammed it and it dynoed about the same as stock, maybe 2hp more. I was pretty unhappy. they told me that it must be a problem with the dyno or my car. I didn't even want to argue. I just tossed it.
Roger
98 SVT E0, Black Blown motor, help on the way...... 97 GTI VR6, Green
