I'm in the process of changing the timing belt since it snapped off. I have the cam aligning tool but my crankshaft pulley doesnt have notches or "teeth" to line up for TDC.
The pulley does however have four drilled holes on the front of the pulley. One hole is directly above the keyway. The second hole is approximately 1 5/8 inches to the right. the next hole (3rd) is approximately 1/2 inch to the right. The final hole is directly below the first one which would be about the 6'oclock position.
My question is twofold,
1.) First, how do I line up the crankshaft pulley without the teeth or notches...do i use the drilled holes as a reference or do I just try to line it up by feeling the piston at TDC? And if that is the case, how would I find the compression stroke and not the exhaust stroke without a compression guage?
2.) For TDC, its #1 correct? Is there an easy way to tell if I'm on compression or exhaust stroke?
