Posts: 699 |
Originally posted by BrApple-SeVT: I don't think that you will need the early SVT gages but you need to search aesthetics becasue for it to work in a pre98 you need to modify the curcuit on the back of the cluster, it has been done, that and you need to make sure you have a non-cable drive speedometer
Yes you do need to get the early SVT gauges. The later ones require a lot more work to get them to function with earlier cars. I believe that there were also 3 different versions of the SVT cluster for '98 cars. The E0 having 2 different versions with differences in how the speedo connects to the circuit board, and the E1 version having a different circuit board layout.
The earliest SVT cluster should work in a pre'98 (except cable driven) without any modifications.
My Cars
1999 Silver Frost SVT - 80,000km #2603/2760 Aug. 10, 1999.
1996 Mercury Mystique LS V6 MTX - retired @ 323,151km.
1995 Ford Contour V6 MTX-sold @ 214,000km
Posts: 4,051 |
Originally posted by KyleH: Originally posted by BrApple-SeVT: I don't think that you will need the early SVT gages but you need to search aesthetics becasue for it to work in a pre98 you need to modify the curcuit on the back of the cluster, it has been done, that and you need to make sure you have a non-cable drive speedometer
Yes you do need to get the early SVT gauges. The later ones require a lot more work to get them to function with earlier cars. I believe that there were also 3 different versions of the SVT cluster for '98 cars. The E0 having 2 different versions with differences in how the speedo connects to the circuit board....
That would make sense because some people have reported problems installing a E0 cluster into there Pre-98 when for other people it works perfectly.
Posts: 6 |
Alright.. Thanks guys.. Ill let you know what I come up with. Spencer 95 Coutour SE
95 Contour SE
Mods: British American Transfer Suspension, B.A.T. Sway bars, B.A.T. Short ram air intake, 17 inch Konigs.....
Posts: 5,854 |
isn't the 95 cable driven? how are you going to get the electronic speedo to wirk with that?
#609 of 2760
Posts: 4,051 |
Originally posted by TGO: isn't the 95 cable driven? how are you going to get the electronic speedo to wirk with that?
Yes, we have established that already.
Posts: 5,854 |
ok so whats the answer to the question?
#609 of 2760
Posts: 4,051 |
Originally posted by TGO: ok so whats the answer to the question?
Have you even read the thread?
Posts: 5,345 |
Since nobody did it, I will start....
Welcome Spencerad2  .
1996 V6 ATX 96K miles
