Bridge Offline OP
As the topic says, which part of the exhaust system is the most restrictive? If I had to guess I'd say the pre cats, but like I said just a guess...
98.5 Contour SVT - Silver Frost
Cupholders - MP3 Deck - Sub - Painted Calipers (Silver) - K&N Filter
Pre-cats
Stock Y-pipe crush flange
Resonator
STD exhaust pipe diameter
Muffler/mufflers
Stock converter
SVT single pipe diameter
The stock Y-pipe crush flange is so bad there is good arguement it could be the worst.
2000 SVT #674 - Check it out!
the heads easily be the most restrictive portion of the exhaust system. factories sometimes
use smaller ports to reduce flow and power and promote better fuel economy.
PS - if you are going with a custom exhaust setup, be sure to use 2.5" piping or thereabouts. anything much larger will kill the backpressure and you will begin to lose torque.
1985 SVO: 4 cylinders, 5 gears, 20 PSI
1998 torredor red SVT contour: #3705 of 6535
need info on your SVTs service/recall/warranty history? e mail me...
Administrator
Administrator
Originally posted by DemonSVT:
[QB]Pre-cats
Resonator
Muffler/mufflers
Stock converter
QB]
Dude, that's pretty much everything!! I agree with the list, too. The exhaust manifolds really suck. SVT should have stepped up and complained a bit for that. Not to mention the horrible Y-pipe.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
Bridge Offline OP
WHere exactly are the pre cats?
Right up by the engine exhaust ports. Each is basically an exhaust manifold with a cat canister--one for each cylinder bank.
"Function before fashion."
'96 Contour SE
Yes, I saw mine today....they look like a really
bad idea. It's those dam greenpeacing environmentalists!
1999 Black SVT #2639/2760 on 08/11/1999; w/18" OZ Racing Superleggera's, Yoko Paradas.
MSDS Headers,Quaife LSD, Borla,KKM,chipped,DMD,Baer 13" Track rotors.
Lowered/HR and Koni's; HPP RSB
3
3
You never loose torque. You just shift the peak farther up in the RPM band
98 SVT E0, Black
Blown motor, help on the way......
97 GTI VR6, Green
H
H
too bad we in emmissions controled areas cant even think about touching those damn precats!
'98 SVT #2253
Currently DEAD!
Cobra Paradise
