Posts: 15 |
Hi,
This morning when i went to start my car all i got was a click and the dash lights flickered and dimmed a bit. It wasnt the usual try to start and the battery dies sort of start, then i tried to start it again and the wipers did one swipe. If I leave the ignition on some of the lights stay on and others flicker on and off. I think that my alternator is on its way out, would this have anything to do with it?
Any ideas would be great.
Thanks for your help.
98 CSVT Silver Frost
190,000 KM's
Posts: 785 |
did you try to start the car with a charger plug on it ?
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
RU-3530/CTA Intake Pipe
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
SPEC Stage one/Spec Alum. Flywheel
HERE
Posts: 644 |
Sounds like your battery is drained. If your alternator is on its way out, then it makes sense. Try boosting it / charging it. If your alternator is the culprit, it should at least start with the booster cables attached.
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Posts: 504 |
ya, if you boost it and it starts, you should at least see your alternator light come on sparasly or sparatically depending on your situation. The alternators go about once or twice on these cars so who knows, it could be that. If it is, it's an expensive LABOUR charge replacement, there is a how-to on the site if you need...
1998 Mercury Mystique LS
- Looking for SVT EXHAUST, SVT Rear bumper (silver frost) and ANY rocker mouldings (side skirts)
Posts: 15 |
I got a boost this morning and it will stay running as long as the cables are attached, once the cables are taken off it dies.
190,000 KM's
Posts: 234 |
Unless your battery is toast.. you can charge it.. what I did when my alternator crapped out on me.. I let the car get charged for like 15 minutes (off) then got a boost and drove it home.. if your battery is totally dead it would need a few minutes to get some what of a charge.. or at least thats what happened to me .. hope all goes well
98 Contour V6 MTX
CTA Exhaust/CTA Intake/MSDS Y-pipe/Bat Handling Kit/Predator Alarm/Spec1 Clutch Kit/SVT Flywheel/G Assurances
Fix your car yourself "It's not a UFO." Todras
Posts: 15 |
Turns out there was a short in the battery. My mechanic tested the alt and it was reading 14. Good news is my battery was under warranty and i didnt have to pay a dime.
Thanks for all the help.
190,000 KM's
Posts: 2,974 |
Glad you got your problem sorted out and it didn't cost anything  . Aaron
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
