Posts: 8,445 |
normal signs of a bad TOB are a grinding noise when the car is in neutral right?
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
Posts: 5,143 |
Originally posted by ElKy: normal signs of a bad TOB are a grinding noise when the car is in neutral right?
more of a wirring, but yeah that would be right...
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 595 |
That, or it came in a SPEC box.
Black 1998.5
3L Oval Port
Full HMS Transmission
Lots of other stuff
Ressurected 06/14/06
Posts: 1,130 |
Originally posted by muntus: Originally posted by ElKy: normal signs of a bad TOB are a grinding noise when the car is in neutral right?
oh snap!
if your TOB is bad make sure you get the six cyl and not the 4cyl TOB. There was a problem where they weren't packaged right. I posted some pics in an old TOB post a few months ago.
Originally posted by Who the F are You?: does your family tree not have any branches on it?
99SVT
235hp @ 6550rpm
212tq @ 5350rpm
Posts: 4,051 |
Exactly why I'm going back to a stock SVT clutch next year when I pull the tranny for a HMS tranny.
The clutch has gotten so loud and drives me insane. Everyone thinks I have engine problems when they hear it.
Posts: 595 |
I meant the TOB. As far as the Spec clutch is concerned, I got the internals coated which makes my Stage 1 very quiet. Sometimes it makes some rollover noise(not loud) and sometimes it makes zero noise. I recommend this process to anyone doing a transmission through HMS.
Black 1998.5
3L Oval Port
Lots of other stuff
Posts: 8,445 |
Originally posted by AliasJerkââ??¢: Originally posted by ElKy: normal signs of a bad TOB are a grinding noise when the car is in neutral right?
well, i guess its kind of a metal on metal whirring. when i put a prybar on the case and listened it kinda sounded like that.
Posts: 21,197 |
Terry says, with your foot OFF the clutch the TOB is just 'kissing' the release fingers of the clutch pressure plate so a worn bearing should be quiet. When you depress the clutch pedal THEN the full load from the clutch springs is on the release bearing. That is the time a bady worn bearing will be VERY noisy.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 4,051 |
Originally posted by muntus: Originally posted by CSVT1214: Originally posted by muntus:
Yeah, sorry. I didn't read enough. I saw noise, and SPEC and put the two together without paying attention to what you were referring to.
I'll have to keep in mind what you said about the internal coating.
Posts: 8,445 |
ok so that rules out the TOB, but does terry have any idea what could be making that noise with the clutch out and the car in neutral?
thanks for the relay of info todd
