Posts: 138 |
Well I'm do for a oil change in about 100 miles and I just bought the new mobil 1 with supersyn. Iv'e been running regular Mobil 1 tri- synthetic and I love it, the question I have is for anybody who has already used the New Supersyn formula and how they like it. Did they notice a difference. Also this wedensday Aussie is supposed to clean my UIM, LIM, and my throttle body and Iv'e heard you should change your oil after doing this, and i'm wondering if I should change it now so as not to go over or if I should wait and go over a few hundred miles. Any input will be helpful.
1998.5 Silver SVT Brullen cat-back off road Y kkm painted chrome grills 5% mirror tint
Posts: 1,152 |
Go over the 100 miles. Sythetic is good for at least 5000 miles they say. I dont go 5k but you can. Aussies house is like FOREVER away.
1998.5 T-RED SVT 18" Team Loco 142's W/ Dunlop Rubber 181.2hp@6900rpm/155tq@5000rpm LOTS OF MODS OF EVERY KIND.... ...Am I a guru yet??? No... not yet.
Posts: 1,770 |
I just did an oil change with the SuperSyn yesterday. Looks slightly darker than the old stuff, but that may have just been my bad memory. Unless I hear about issues, I'll probably keep using it.
Posts: 3,419 |
The only thing I noticed about the SuperSyn was that there seemed to be a little brown fall out at the bottom of the 5 qt jug. Never thought I had to shake oil before use. I guess it's the wear additive. Not a lot down there, so I don't really care. Otherwise it seems the same so far. We'll see what gas milage says but I'm fine with it. All it is is Tri-Synthetic with a new additive AFAIK.
Posts: 128 |
oh good... precipitates in the oil? no thanks, I think I'll stay away from that.
T-Red SVT E0 #2321 of 6535
Posts: 1,701 |
Originally posted by SilverbulletSVT1: ... Iv'e heard you should change your oil after doing this, and i'm wondering if I should change it now so as not to go over or if I should wait... Cleaning the intake can be a bit messy and some gunk and dirt will end up in your oil. Better to wait until after the work is done to change the oil. A few hundred extra miles isn't going to make a siginificant difference to the oil or engine. (A nice clean intake should be well worth the wait  )
Posts: 138 |
Thanks for all of your imput. I think I will wait, makes more sense. Plus my oil is not that dirty, and I just added a quart because for some reason it was below max. No oil leak though, at least that I can see.
Posts: 352 |
Go to Mobil1 and print out a form...with your receipt, UPC from SuperSyn case, and this form, you'll get a free stainless logo'd coffee "travel mug" and a free sample of Green Mountain coffee!! ...Ed
2000 Silver Frost SVT #1625 14 Jan 2000 Dual Mode Dampener A/C switched K&N Dropin Magnecor
Posts: 581 |
From what I was told at my work its the same stuff....just a different name and new bottle
-Mancho- cars name is Connie 99 Silver Frost SVT #1986 k&n filter with cut out box true duals w/ flows  Ground Controls with 17's mille miglia ... Hightower headlights 15.4 at 90.29 at Milan dragway before the true duals
Posts: 3,419 |
Originally posted by bcandiloro: oh good... precipitates in the oil? no thanks, I think I'll stay away from that. Well, keep in mind that this jug probably sat for weeks without really moving (it was priced cheaper per qt than a single qt or a case of 6 qts). The oil in my engine doesn't sit for that long. Also, it wasn't like a 1/4" of sludge or anything; just a little brown "stain" at the bottom of the jug. Nothing that concerned me really.
