#1620400 07/31/06 01:34 AM
sjthuss Offline OP
I was reading something the other day about using an adapter kit and software to read OBD codes using a laptop. Has anyone tried this? Which kits are the most useful/user friendly/affordable? Any recommendations? I would like to try this, but I'm hesitant to put out much money for it.
#1620401 07/31/06 01:39 AM
sjthuss Offline OP
This auction on Ebay is where I got the idea. I already have a laptop that I could use though, so it shouldn't be nearly this expensive to get the needed software/adapters.
http://cgi.ebay.ca/OBD2-OBDII-Diagnostic-Laptop-for-BMW-Mercedes-VW-etc_W0QQitemZ220011057591QQihZ012QQcategoryZ30921QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
#1620402 07/31/06 01:58 AM
alex Pepper's OBD-II software is THE recommended laptop based scanner software for CEG.
Check it out, google it.
#1620403 07/31/06 01:47 PM
9
I've used Scantool.net's scanner, my buddy has one. It works good. It allows you to monitor just about everything. The only thing that we couldn't get it to show was fuel pressure... Which I would think the PCM would know...
They have one that's just for Ford thats around 100 and another that does all OBD-II for 130 I think it is...
1999 Mystique LS V6 Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
#1620404 07/31/06 01:53 PM
Only if the vehicle is equipped with a fuel pressure sensor, which the early Contour does not.
Contours with a returnless fuel pump should have the sensor.
Steve
#1620405 08/01/06 02:24 PM
9
My car is a very late 99 with returnless so I would assume it would...
