Posts: 18 |
So as i said earlier I'm building a hybrid, '01 3.0L Escape bottom end with rebuilt '98 2.5L SVT heads. All the information i've found on the site talks about using all the 2.5L timing components(chain, sprockets, tensioner arms, chain guides) But on the 3.0L block I have, it doesn't have the 2 dowels that the 2.5L tensioner arms pivot on. So i'm wondering if i should use all the 2.5L timing components except to substitute in the 3.0L tensioner arms and chain guides.
-Seth
Posts: 1,746 |
You use the timing components of the cams.
Such as...SVT cams? Use the SVT timing components
Using 3L cams? Use the 3L timing components
I don't know what you mean by the 2.5 stuff doesn't fit on the block...because it should.
2000 Contour SVT
SF - #542 of 2150
Posts: 18 |
i'm saying that the 3.0L block i have doesn't have the pins that the 2.5L tensioning arms pivot on. I'm kinda stumped, I thought all Duratec bottom ends had the same architecture.
Posts: 595 |
Black 1998.5
3L Oval Port
Full HMS Transmission
Lots of other stuff
Ressurected 06/14/06
Posts: 310 |
IIRC, the pivot dowels for the guides / tensioners are actually located on the heads, not the block. That's why your block doesn't have them.
I'll put holes in him!!
Posts: 21,197 |
Oh boy. Countdown to destruction.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 1,336 |
Originally posted by todras: Oh boy. Countdown to destruction.
5
4
3
2
1
Destruction
Posts: 1,746 |
Originally posted by SvtTour98.5-3: IIRC, the pivot dowels for the guides / tensioners are actually located on the heads, not the block. That's why your block doesn't have them.
What he said.
2000 Contour SVT
SF - #542 of 2150
Posts: 18 |
Posts: 1,746 |
Originally posted by ncalaskan: sorry....
don't be sorry. Just get it together and running
2000 Contour SVT
SF - #542 of 2150
