Posts: 422 |
What MAF voltages have you folks observed at idle with stock and not-so-stock MAF sensors?
2000 Mercury Cougar V6 ATX. 16.0@87MPH, 155.0 FWHP
Posts: 422 |
Posts: 153 |
Originally posted by Frank: What MAF voltages have you folks observed at idle with stock and not-so-stock MAF sensors? .46 lbs/min and 86V (I assume that should probably be .86)
97 SE MTX, KKM, UR UDP, 19# Injectors, SVT TB, SVT UIM, SVT Flywheel, Grizzly Street Clutch, Upgraded motor mounts, mystifed precats, brand new main cat, SVT exhaust sans resonator, 205-55-15 Dunlop SP5000's 154hp / 156 tq before the SVT exhaust, SVT dual honed upper and swapping the mystery main cat for mystery precats. My Profile
Posts: 3,562 |
I've heard anywhere from .86V to .89V. Make sure to check it in the garage with the door mostly down to make sure no wind gets to the MAF. A sneeze can make the voltage jump by quite a few points by itself let alone a slight breeze!!!
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 229 |
I checked mine tonight. It's .89V
99 CSVT Green/Tan 13,700Km # 84 of 2760
For Sale 96 Contour GL 2.5 ATX 120,000Km K&N Air Filter Mobile 1 E1 SVT Wheels & BFG G-Force Rubber Aluminum Painted Front Grill
Posts: 539 |
mines about .7 thats prob y i am throwing a code....damn pro-m
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
Posts: 422 |
Aha... very interesting. My gutted stock MAF with screen hovers around .65. It does seem to idle much more smoothly when I crank it up to around .85 with the optimizer. I thought that was too high, but I guess not!
Posts: 105 |
My idle voltage is .64 on stock MAF and runs smooth.
Green 2000 SVT #1166 mods-K&N open air filter & Custom heat shield, Custom y pipe and 30 in resonator,DMD, arm rest heightened http://www.geocities.com/savinoss/Cars.html other cars-89 sable 197000 miles and still going-Wifes car 99 Mystique V6 5 spd
Posts: 422 |
I just did some testing myself...
Stock MAF and stock SVT airbox: average of .7 at 720rpm, never dropping below .65. Gutted MAF and open K&N: average of .63, never dropping below .56.
I used the optimizer to set the idle for a steady .70-.71 with the gutted MAF and K&N. The interesting thing is that the MAF optimizer seems to smooth the MAF's output. Instead of varying from .65 to .74, it never goes below .70 or above .71. Hmmmmm....
