Posts: 539 |
Please read linked post.
after reading this i had a convo. with the president of ram and appartently there are some probs there and they want me to send the clutch back and i will be credited thru summit
http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic;f=1;t=014110#000009
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
Posts: 563 |
I am skeptical its the clutch I think I am going for a flywheel that wasn't stepped right. The moment of truth will be in a couple of hours. I took measurements on three diffrent clutch and the ram actually has a thicker clutch disk. Other qualitis were the same like the same manufacture of the pressure plate made by LUC. Went over the whole thing with a caliper all having same measurements or better qualites like a thicker clutch plate. One mesurment that we over looked is the edge stepping on the flywheel. The fidanza was a little deeper we thought it would not make a diffrerence bud today we are putting back in the stock turned and grinded one. All in all Someone is going to pay or go to court. Today will eliminate all varibles if it still slips we will know its the clutch. By far this is the biggest nightmare of my automotive life. Current debt is up to 3500 dollars. It all started with a Drag race.
Dustyn Red 1998 SVT E1 95 Mustang GT Yeah there both slow New ram clutch for sale Sho shop pullies and belt for sale 30 bucks
Posts: 539 |
Yea it was expensive for me to get it alright. first clutch job cost 400 clutch 100 flywheel insert and 700 install. got the car back...messed up clutch and bad noise from trans.. so i got a used trans 450 new clutch 50 with through-out bearing and flywheel insert and install 750. so yea it def costed me a lot of money
Posts: 98 |
Its the flywheel tolerance thats off according to Terry  Sounds like a run of bad luck man good luck with the tranny. I have had my run of bad tranny problems to.
1999 V6 MTX Black Cougar
Jacobs ignition system, Borla dual exhaust, Sho shop y pipe and hi flow cat, gutted precats with MIL eliminators, IAT rewire, vitek ignition wires, SCA CAI with monster flow filter, Unorthodox racing pulley, BAT rear strut brace, Battery relocation to trunk, eibachs, KVR crossdrilled/slotted rotors, freedom design strut brace and Tuned S-AFC
Waiting to be installed: svt engine with 11k miles on it/ fidanza flywheel/Quaife/energy suspension engine mount inserts.
Posts: 2,848 |
maybe off topic but what is involved in changing the clutch? I *might* have to replace mine soon...can you just swap out the clutch or do you need a new flywheel/etc.? I ask not because I don't want to buy all the correct parts, but because I don't trust ford to get a replacement SVT flywheel, which is (duh) lighter than a stock contours.
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 52 |
What kind of Clutch and flywheel do people recommend?
Maybee I tried the search function already
Posts: 5,805 |
If the stoc flywheel is burnt it should ALWAYS be reground before fitting a new clutch....
Posts: 2,848 |
Posts: 157 |
RAM, bites @ss. 3 of my friends had them in the stangs and in a probe. They went out in 30,000. read my sing and see! this is by far the best clutch and flywheel, i have ever had. good luck
98csvt(red)white 19''Axis se7ens on toyo 225/35/19's injen intake,cust exhaust, High Rev's racing clutch,and flywheel .whatever its takes to run 12's (system)Eclipse 5442,Boston 6 1/2" pros, Eclipse 5x7 point scourse,PPIpc4400,PPIpc2600(chrome),power cap,2 12"JLW6 YOU WILL RESPECT THE FAMILY CAR
Posts: 563 |
Update on the clutch Crisis: Like black coog said it was a tolerence issue with the flywheel and the clutch. The stepping on the fidanza flywheel is a little off causing the clutch plate not be able to be pushed to full force. To prove my point I first had a ram HD setup in my car everthing new from the the flywheel to the clutch kit. Babyed it for 600 miles and then took a hard down shift and slipped. I knew something wasn't right so I called ram and they sent an upgraded clutch disk from the already kevelar disc. It was the mettalic setup that is capable of running slicks just to tell you how heavy duty it is. Put that in it also slipped. I ordered a stock replacment from ford and measured everything with a caliper. Everything was the same only diffrence was the ram clutch disk was thicker which was better. I had three clutchs laying out on the table looked at the pressure plates and all three were made by LUC. Finally I had the stock flywheel turned and grinded the proper way. Put that back in the car with the metallic setup and I am a very happy customer. I put it through hell last night and no way will it slip. So the whole time it has been the flywheel. The whole time I had the flywheel in my car I don't think it was worth 400 dollars just my 2 cents. I'm sure the flywheel will work with other setups like jiakos recent setup with centerforce. This is good advice to know before you go off buying this and that and find out that it doesn't work. Just wish it wasn't at my expense. :rolleyes:
