Ken Gibbons
Riverview, FL
'00 SVT Silver Frost Metallic/Midnight Blue
SC6152E Precision Turbo
Custom Twin Core Water / Air I/C
Blitz BOV
TiAL 38mm Wastegate w/ 5lb Spring
HKS Electronic Boost Controller
HKS Turbo Timer
8.5:1 CP Pistons
Pauter Rods
PnP Fully worked Heads
Driveshaft Shop's Stage 5 Axles
Spec Stage 5 Clutch w/ Spec Lightened Flywheel
Walboro 255 lph Fuel Pump w/ Boost it pump
65# Injectors
75mm Bullet Mass Air
DMD
Quaife LSD
Escape Oil Pan, Windage Tray and Pickup
Intrax Springs
Koni Struts
BAT Camber Kit
Mirko Racing Subframe Bushings
BAT 22mm Rear Swaybar w/ bushings
19" Centerline RPM Wheels weighing in at 15lbs each
wrapped in Nitto 555 Tires 225/35/19
3 Pod Pillar w/ Oil Pressure, EGT, Water Temp
Coin Tray Boost Gauge (30lb , 30Vac) all guages are Phantom Series w/ Green Bulb Condoms
I believe this is the majority of things...so many things I cant keep track..should be on road within next week..has been 2.5 year project and a lot of money lost from thieving mechanics
however, I have since prevailed and will soon be breaking it in
-Ken
