Posts: 13 |
I have a cougar with a 3.0 in it. I will be adding the SVT UIM LIM and TB, is there going to be any odd ball gasktets or parts needed for that swap?
99 merc cougar, Auto cross junkie
Posts: 562 |
Have you port matched the 3L heads? Check out the 3.0 Duratec section for more information, and search, you'll find the info quickly. BTW, use the function AND as well as making sure you hit all posts in the drop down menu, it'll make your search quick, easy, and loads more useful, also read the stickies at the top.
'99 Spruce Green SE "Sport" 'Tour, 2.5L MTX...80K and running like it just rolled off the lot.
Tryin' to add an extra .5L ASAP
Posts: 13 |
I had adaptor plates made up to mate the cougar LIM to the engine. I am guesing I will have to open the holes up on them a bit
Posts: 5,810 |
If you already did that then you won't need anything special I don't think.
See My Mods
Posts: 1,746 |
nope, just a 10mm socket and a ratchet.
2000 Contour SVT
SF - #542 of 2150
Posts: 611 |
Don't the manifold bolts all the manifold bolts use an 8mm socket?
If you do have an adapter plate post a picture of it. I'd be curious to see how that works. I thought we didn't have enough clearnance under our hood to get a plate in there that would work. The plate would have to be less than an inch thick and would be a pretty drastic change.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
Posts: 1,746 |
yea, I just thought that after I posted...figured someone would say something. I cant remember everything!!!! you can assemble about all of this damn engine using a 8mm 10mm and 13mm
2000 Contour SVT
SF - #542 of 2150
