Posts: 2,066 |
Originally posted by Jason King: It will be available for the 2.0 and the 3.0. The interface only gets better with the actual version. If you thought that took forever to down load wait untill you see the big file with 3D graph's, 2d graph's ... etc etc. Why not the 2.5 liter also???
Posts: 7,329 |
Originally posted by jcboeckl: Why not the 2.5 liter also??? He has to have miss-typed or they are missing the majority of the market on this platform. Especially since this platform never had a 3L in it stock
Posts: 97 |
Hehe, you can thank us Thunderbird owners for supplying such a sufficient program.
+Ford Thunderbird 1997 - V8 +Ford Contour 1995 GL [REST IN PEACE :(][Champagne|ATX] -9mm Ford Racing wires -CTA Intake Kit -Removed exaust resonator
Posts: 100 |
Originally posted by DemonSVT: Originally posted by jcboeckl: [b]Why not the 2.5 liter also??? He has to have miss-typed or they are missing the majority of the market on this platform.
Especially since this platform never had a 3L in it stock [/b]Yep, typo, sorry!
14.6 out of a 12 valve 3.0 Taurus A wise man once said, rather then watch a girl wrestle I would rather see her box.
Posts: 100 |
Originally posted by WaLieN: Hehe, you can thank us Thunderbird owners for supplying such a sufficient program. You can thank my partner Spiro for supplying the T-Bird with that program, you can thank me for supplying YOU with this program
Posts: 100 |
Originally posted by AirKnight: What exactly does this do? The program itself I mean. I went to Shiftmaster's webpage, and they didn't say anything about their board working with the Contour.
[EDIT: Whoops! They must be a different EEC Tuner than the Shiftmaster one] Same basic principle, but I will be supporting more then the Mustangs.
Posts: 5,296 |
How much will it cost for the board when you release it? If this is better than eManage, I'd get this instead. I would rather have a tuner board like this than having to splice 200 different wires for a piggy-back computer.
Posts: 100 |
Originally posted by 1st 3L 95SE Wannabe: How much will it cost for the board when you release it? If this is better than eManage, I'd get this instead. I would rather have a tuner board like this than having to splice 200 different wires for a piggy-back computer. It will be in the upper 400's to $500 range depending on some supply problems we are having. And your right, only one wire and no splicing
Posts: 5,296 |
So, when will it be released? And the more important question is, how will it compare again the eManage as far as control over the PCM goes.
Posts: 1,444 |
didn't work. it wants unlock codes.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
