IMPORTANT! This will NOT work on anyones car. Also it is a VERY preliminary version of what we ALREADY have. But this was a small enough file for people on dial up to get the idea behind the Tuner. Check out the HELP files for Lots of information. The help files are different for each vehicle.
Let me know what you guys think.
14.6 out of a 12 valve 3.0 Taurus A wise man once said, rather then watch a girl wrestle I would rather see her box.
I d/l it. So it's gonna be programmed for the contour? Zetec and Duratech? Do you have to know a whole bunch to program it? It has a good interface and easily managed files. I still wouldn't know what to do though. Could you download settings from some1 else and then put them on u'r car's computer using the program? Does this replace the need for a chip or is it a chip? It sucks that you have to have a laptop to use it, either that or drag your PC outside.
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
yeah, it's cool, and seems pretty easy to use. changing values could be changed so that can be done a little easier. i would definately blow something up with this program ...shift point in relation to TV...uh, television is related to shift points.
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
It will be available for the 2.0 and the 3.0. The interface only gets better with the actual version. If you thought that took forever to down load wait untill you see the big file with 3D graph's, 2d graph's ... etc etc.
What exactly does this do? The program itself I mean. I went to Shiftmaster's webpage, and they didn't say anything about their board working with the Contour.
[EDIT: Whoops! They must be a different EEC Tuner than the Shiftmaster one]
UBRF.org , Western New York's Premiere Automotive Forum.
