Posts: 344 |
Does this increase the chances that it might chip or could be a barely different color? I know the previous owner said the driver side door has been repainted.  If anyone could shed some info on this that'd be great.
Posts: 1,746 |
If I were you, I wouldn't risk it. If you know in fact, that the front door has been repainted, I doubt any body shop would remove the door moldings just to repaint the door. They would probably just tape them off and paint accordingly. If the paint job wasn't too long ago, find out what shop did it and tell them what you want to do and ask them if they removed painted then reattatched the ding gaurds...
2000 Contour SVT
SF - #542 of 2150
Posts: 344 |
Originally posted by posthuman63t: If I were you, I wouldn't risk it. If you know in fact, that the front door has been repainted, I doubt any body shop would remove the door moldings just to repaint the door. They would probably just tape them off and paint accordingly. If the paint job wasn't too long ago, find out what shop did it and tell them what you want to do and ask them if they removed painted then reattatched the ding gaurds...
It was at least a year ago and I bought the car an hour away, I probably shouldn't risk it
Posts: 9,442 |
Peel a bit away, if it looks bad stick it back on there....
Posts: 3,637 |
Originally posted by BK4293: Peel a bit away, if it looks bad stick it back on there....
dont even bother, the risks outweigh the benefits.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 344 |
Originally posted by Tourige: Originally posted by BK4293: Peel a bit away, if it looks bad stick it back on there....
Thanks guys, looks like I'm keepin the ding guards
[edit] I emailed the previous owner and he says it was the quarter panel that was repainted, not the door, so I might be in business.
Posts: 1,150 |
i only took mine off because i knew I was getting my entire car repainted. a door panel was painted and oh does it look like shiaaaat when you take the ding gaurd off! dont risk it!!!!
Posts: 344 |
Originally posted by blu_fuz: i only took mine off because i knew I was getting my entire car repainted. a door panel was painted and oh does it look like shiaaaat when you take the ding gaurd off! dont risk it!!!!
If I get off work early tomorrow I'm doing it. I get my Porter Cable tomorrow and will be polishing up my car sometime this weekend.
PS, i found out it was the front quarter panel that was repainted, not the door.
Posts: 344 |
Update: sooo, I had nothing to do tonight so I decided to do it. Turns out the whole side of the car has been repainted, both doors. I have a nice racing stripe on the side, while the other side is FLAWLESS, mirror-like. Is it possible to sand down and repaint only part of it, or will I have to get both doors entirely repainted? It's not THAT visible but it sucks.  Pics tomorrow.
Posts: 144 |
What a cock so the previous owner lied? or what...
