Reebs Offline OP
My starter went out this morning and so I replaced it and all was good at first. Then after driving it for about 5 minutes my speedometer dropped to zero and hasn't worked since. I know I had to twist and turn the starter to get it out and past the throttle bracket near the throttle body, but I didn't think I hit any of the wires or cables enough to mess them up.
Do you guys think this was just a coinicidence that my speedometer stoped working right after I changed my starter, or could they be related? The funny thing is that it did work for the first few minutes of driving. Is any part of the speedometer cable even in that area?
I am going to check my fuses...
Any ideas or opinions are greatly apprecitated.
Thanks!
Jeff
For Sale - 96 Tour Sport 2.5L MTX with SVT Exhaust, pre 98 trunklid with newer Contour Sport spoiler instead of lip spoiler, newer Contour sport rims. Newer paint job. Brand new floor mats. Rust Free! PM me for details and pics.
um, if you have a 96 there is not speedometer cable ...
check fuses and wires related to the vss and speedometer
Reebs Offline OP
I'm sorry... I thought I mentioned that this was on my 98 SVT and not my 96 SE. Anyways, does anyone know which fuse or fuses to check? Is it possible that I messed this up in the starter replacement!?!?
Thanks,
Jeff
doesn't matter, the early 95s ar ethe only ones with a speedometer cable ... check the wiring to the vss
Reebs Offline OP
Thanks, although I am not quite sure where the VSS is but I will go find out.
Any other ideas guys!?!?
it is on the back side of the trans near the starter
Reebs Offline OP
Then it must be possible that I jiggled something loose. Thanks for your help!
I will give a report with the problem when I figure it out... or shall is say if I figure it out!
yes, it has two wires running to it and I beleieve there is a connecter near by, you can get to it by removing the accordian tube and reaching down to it iirc
