Posts: 1,788 |
Time to call in the hook.....
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 34 |
Originally posted by projectSHO89: Time to call in the hook.....
Tow time i presume. I think I've learned my lesson don't drive neglected cars or the person you borrow it from will immediately blame you. ![](/ubbthreads/images/graemlins/rolleyes.gif)
I asked him about towing it to Beasley Ford and he rather just let it sit in a parkinglot.
Thanks again I think i'm done putting any time into this.
97.Contour.GL.ATX
89.Dodge.Colt.4G63T
Posts: 34 |
The car BlueBook's for $2800. The labor is $300 and a 90day warrantied tranny from the junkyard is $400.
Is it worth it? I have the opprotunity to buy the car for $1000
97.Contour.GL.ATX
89.Dodge.Colt.4G63T
Posts: 5,345 |
How many miles on the car? What options? Where are you getting $2,800 BlueBook value?
1996 V6 ATX 96K miles
Posts: 54 |
Ok im at 124k miles and in the last month my tranny has been going crazy. It will start out ok then as I drive and slow down it will jerk when i give it gas into 1/2 and the other gears are realitevly fine. When I start it in the morning It was fine for a little while. Today as I was drving home it's starting to have problems down shifting just a little and then finnally the o/d light started blinking as I was trying to get home. I'm afraid it's broken now but maybe could have been fixed if I had looked at this a month ago. Also when im in gear and not moving my spedo gage bounces from 0 to 10 mph. Maybe something is cooking it and thats why it is shifting bad because when I first start it still runs ok. I've tried calling part stores about the TSS and none have it around here. I added lucas that didn't help much. When that light started blinking I was freaking out. I stoped my card and started it again and it was off like it's supposed to be. I can't afford to replace the tranny and I can't buy a new car. I drive this thing 400+ miles a week and it has been well maintained. I run full 10w/30 synthetic in it every 3000-4000 miles. Replaced belts, plugs, sp wires, water pump and both belts as pm. Only thing that has ever broken is the timing belt tensioner but that was fixed and no problems since then until now. If i am cooking my Transmission i'm just making it worse every time i drive it and I might actually need a new one now that its been a few weeks. New TSS, get the cat checked, anything elese I should get checked before I borrow the cash to get my car fixed ?
Man I guess 114k is a lot of miles for a '00 ![](/ubbthreads/images/graemlins/shocked.gif) .
Posts: 5,345 |
Posts: 54 |
Thanks for the info Tony I will try that later today. I called napa and they have a vss for a manual transmission, is that the same thing, the guy was like huh what the heck is a vss and they did not have anything that resembled a tss.
Posts: 5,345 |
Originally posted by Diftgog420: .. I called napa and they have a vss for a manual transmission, is that the same thing,...
Different.
From www.teamfordparts.com
VEHICLE SPEED SENSOR, Contour, Mystique, 2.5L, Automatic Trans., From 2/1/95 95-00 MSRP $51.18 CEG $28.56 Order By Description. Parts & Prices For Estimating Only. VEHICLE SPEED SENSOR, Contour, Mystique, 2.5L, Manual Trans., From 2/1/95 95-00 MSRP $51.71 CEG $28.85 Order By Description. Parts & Prices For Estimating Only.
Posts: 54 |
I bought 12 quarts of castrol mercon V ATF will that work or should I use some thing else. Man shes getting worse.
