#15819 05/16/02 05:31 AM
9
9
I installed a k&n conical filter to my intake and now there is this sound coming from the end of the intake. how i instaled it was i just took the top of the intake box off and disconected it from the maf and left the bottom piece of the intake box as it is. i connected the filter to the maf and let the filter rest in the bottom piece of the intake box. I left the bottom piece in hope that it would help to maybe shield some heat. The noise sounds like when you blow across the top of a beer bottle and it makes that humming whistling noise, you know what i mean? and it still makes it when i take the filter off and even when i try to move the incoming airflow around with my hand. any ideas of what it might be?
You've got the moose!! Check in the FAQ on contour.org for a fix. Either the cheap DIY $1.25 fix, or the $50 official fix from ford (replaces IAC tube and IAC valve).
1996 Contour SE Red V6 MTX
1995 Contour LX Champaign V6 ATX (my wife's beater)
SuperChip | KKM Intake | Ford Motorsport 9mm Wires | Bosch +4's | Mobil 1 | No Resonator | Knauberized Doors | JSP Custom Wing | Re-wired Fogs | Red Painted Calipers | 98+ Sail Panels | Vuncannon Alarm | Lighted Moonroof Switch | Pioneer Head-unit | Pioneer 6x8's
