H
H
anyone else have this problem? Right by the B pillars on both windows, they make a screeching sound and there are scratches that I feel are getting worse and worse. I changed the moldings on it and still the same thing. Took the door panel off to look but there is too much metal frame to see anything.
F
F
I just noticed my right front door has a scuff along the back edge too. My left rear door glass is badly scratched, it was because of tiny pebbles caught in felt pads. Now I will look at my right front ..
check the weather seal, on my 95 the metal bar inside it is expossed and has corroded and is scratching the window
H
H
Weather seal is the one that goes along the door horizontally? I just replaced them and I get the same thing
yes it is. Mine have been opened and expanded from all the rain and snow this car has faced over the years. I have the same exact problem to. I've tried all kinda of cleaners to try and fix them or make them look good but to no avail. You're just going to have to live with them, unless they're badly scratched, I wouldn't worry about it, looks to be a common problem. If it isn't the weather stripping, I would assume its an exposed metal bar inside the door. Does it look like 1 or 2 vertical lines to the very left of your driver window (left when you're inside)?
1998 Mercury Mystique LS - Looking for SVT EXHAUST, SVT Rear bumper (silver frost) and ANY rocker mouldings (side skirts)
