I went to clean the throttle body and noticed oil between the MAF and the throttle body. Also, some light oil in the throttle body. What would cause this? I wonder if this is what was causing my car to stall (1999 V6 Mystique 108k miles)? Also, what does a MAF cost? Thanks!
Lack of vacuum? Have changed the PCV valve before? Supposed to be changed every 60K miles.
I changed the PCV about 10k miles ago. Could this cause my car to stall?
.. Could this cause my car to stall?
If the PCV valve is stuck, sure.
http://www.automedia.com/PCV/Valve/ccr20050101pv/1
