lestro Offline OP
Hi, I've got a 96 contour zetec with no spark and an trying to follow the autozone guide, but I'm having trouble finding the ignition control module. i've replaced the crankshaft position sensor and connector, the coil tests ok, no blown fuses that I can find, I tested the cam sensor by putting it on an ohmmeter and moving a piece of steel near it and got a hit. Does anyone know the location of the icm? thanks
Originally posted by lestro:
Hi, I've got a 96 contour zetec with no spark and an trying to follow the autozone guide, but I'm having trouble finding the ignition control module..... Does anyone know the location of the icm? thanks
Er..., 1995 models only?
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/c3/d7/0900823d801bc3d7.jsp
Maybe you want the ignition coil?
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/c4/02/0900823d801bc402.jsp
lestro Offline OP
gosh, i guess that would explain why I couldn't find it, I guess the 1995-1999 threw me off.The coil checks fine with a digital meter. Thanks for the info
