Posts: 1,746 |
yes. check ajusa.com prices on filter, usually cheaper prices there
2000 Contour SVT
SF - #542 of 2150
Posts: 1,254 |
find some kinda heat sheild at least. with that open filter in the engine bay will have "heat soak" problems, traffic summer, you know....dirty filters too.
Posts: 130 |
Originally posted by MyCaiNsBroK3N: find some kinda heat sheild at least. with that open filter in the engine bay will have "heat soak" problems, traffic summer, you know....dirty filters too.
Yes.. i just did some fourm searching... makes me a bit skeptical( power loss, stuff like that), i dont mind making a heatsink (garbage can) or w/e but, i dont want to waste time and money putting this stuff on.. ya know?
will it be worth it in the end?
i dont expect to get 20hp or anything like that but maybe a mpg or 2 and maybe a horsie or 2?
'98 2.5L Mystique LS T-Red
Posts: 7,100 |
With realistic expectations like those, then you won't be disappointed at ALL!
good for a mpg or so, and maybe 1-2 hp. the mileage increase will likely be negated by the increase in pedal useage from the GREAT sound it makes.
'99 CSVT - Silver #222/276
Posts: 4,140 |
The K&N cone with a good heatshield provides essentially no power by itself. It does, however, provide a bit of improvement to throttle response: optimize the TB too to make it more pronounced.
And it sounds frickin' awesome.
Posts: 1,029 |
Agreed. I'd do it again just for the sound.  .
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
