#1610087 07/14/06 05:05 AM
8
8000RPM Offline OP
Do any of you with SVT's experience a squeaky sound when shifting hard to upper gear in high rpm's? It happens exactly when you let the clutch go fast, say at 6500k rpm or more. Will do it when you shift to 2nd or 3rd gear. mine does it and my friend's svt is also doing it. is it something normal for these cars or is something about to come apart? thanks.
Its the serp belt squealing while it loses tension under the hard shift. It isn't your tires squealing, and it isn't a bad thing (not gonna blow up, etc)
8
8000RPM Offline OP
gracias. i know it's not the tires, unless i really spin them (happens sometimes but it's a different sound) but the belt makes sence. thank you
