Well gas sepd. odn. and temp gauges are not working I just got done do the dashboard warp fix(kind of). Well I figure out the vent problem from before now this. I check my voltage and i does not get below 14 no matter what. I took out my gauges cluster and everything was hooked up fine. It goes directly to the wiring harness so I am trying not to dig it that yet. I put my voltmeter on all the connections on the right clip and only got on hot. I check all my fuses and they were fine. Is there a relay that possibly is bad? BTW I have a 2000 svt. Once again any suggestions are welcome. Thanks joe.
