hrm.. screw? LOL its a crank system, just unmount the motor ASSEMBLY, and use in the crack (screw) i guess, and rotate it to open and close it manually. If you want, home depot has a crank that fits that and all you would have to do for a permenant fix remove assemble, drill hole through plastic cover, and crank away
