Hi Folks,
I just wanted to let you all know that SHM/Zone-5 Performance Products has activated our Technical Message Board to address all of you potential questions/issues/problems with the MAFterburner product line. You can find the forum at:
www.seanhylandmotorsport.com/forum
Also, be sure to check out the FAQ, installation notes, tuning guidelines, and the latest Tech Tip on how to set the WOT Breakpoint voltage for best performance.
Take Care,
Creators of the MAFterburnerTM
'03 Sonic Blue SVT Cobra Coupe
HoosierContour, I read your post over there.
0.935 volts is NOT necessarily 12.5:1 A/F. Stock O2's are not a reliable means of measuring air/fuel ratio unless you are trying to measure 14.7:1. If I tune to 0.935, I foul the heck out of my plugs (i.e. WAY too rich). Need a wideband O2 and a dyno to do it right.
