#1609117 07/12/06 09:47 PM
about 3 weeks ago i bought a 98 contour SVT, about a week after that i blew a connecting rod out of the back side of the block..
does anybody know where i can find the best/cheapest swap for my car.. i heard about the 3.0 escape hybrid swap.. it sounds like the easiest way to go about getting it fixed.. if anyone has any extra information on where i could find this motor and what i will need to get it done (i.e. pictures, diagrams ..) anyone that has done this swap.. pretty much i dont know [censored] about this swap, and i hardly even had time to get to know my own car befor it took a [censored] on me.. so im pretty pissed about it all and just looking for some help, i have been out of a car for a couple weeks and im makin payments on somethin i cant drive. any information on what you think would be the easiest way to fix my car would help..
98.5 Contour SVT
where are you located? There might be someone in the area that could do the swap for you.
Welcome .
Located in Lansing,MI area
98.5 Contour SVT
Easiest and quickest fix would be to do a straight 3.0 swap. For this you need a sable/ tuarus intake/TB set up. The escape UIM does not fit in the engine bay. Other things you need to do to both engines is cut flex plate bearing, cut 2 block ears for alternator bracket, use modified EGR tube, swap timing cover (possible not escape), and make fuel rail for your return fuel. Other than that it is a near drop in engine.
The escape engine comes with a updated oil pan and pick up tube. The taurus/ sable engine must use your older style 2.5 oil pan or buy the new style oil pan (about $200).
If you buy a sable/ tuarus engine you should be able to get the swap done for about 600 if you use all your original parts and do a straight swap.
If you use an escape block you will have to buy a sable / taurus UIM / LIM / TB to put on the escape block. Don't pay more than 75-100 for these parts. A lot of people did these swaps and have the parts left over. Just ask around, somone don't need them.
Look at the stickies in this forum, there is plenty of info there.
Check Car part. Talk em down on the price and dont pay more than 500 for an engine with less than 50k. I paid 200 for a sable engine with around 47k.
www.car-part.com
2001++ Escape Engine 3.0 Duratec
2001++ Ford Tuarus or Mercury Sable Engine 3.0 vin S Duratec
check Ebay. www.ebay.com
call LKQ http://www.lkqcorp.com/home/home.asp They have quality parts and very good prices. That is where I got my engine as well as many others.
Good luck.
Hey if you need some help when you figure out what you are going to do shoot me a pm. I'm in the area and wouldn't mind getting my hands dirty.
So you aren't selling the car I take it.
i just payed $5000 for the car about 3 weeks ago.. no way in hell am i about to take a 5000$ loss on it.. that options kinda out of the window.. i need to get it fixed ASAP then ill be gettin rid of it
98.5 Contour SVT
