Posts: 1,812 |
Originally posted by Toadster: woohoo! good to see you over here Jason! so - i'm assuming this would probably not pass a smog test - right?
but we could program a "sniffer" mode, then the performance mode... right?
congrats on your success with your Bull!!... i'm sure there are some guinea pigs on this site that would be a great testbed for the 'tour family too! Or, one could just remove the program entirely...essentially returning it back to stock form for sniffers. I think this would be easier than programming another setting.
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 3,248 |
Jason, Trick is having someone who knows how to use this thing. When the SVT version is available are YOU available to tune & have dyno acess? I am in richmond Va, just down the road..
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 443 |
Originally posted by Derk2000: Originally posted by Toadster: [b]woohoo! good to see you over here Jason! so - i'm assuming this would probably not pass a smog test - right? but we could program a "sniffer" mode, then the performance mode... right? congrats on your success with your Bull!!... i'm sure there are some guinea pigs on this site that would be a great testbed for the 'tour family too! Or, one could just remove the program entirely...essentially returning it back to stock form for sniffers. I think this would be easier than programming another setting.[/b]That is what I was refering to.
Posts: 3,419 |
Originally posted by Jason King: ... I'm actually talking to someone with a supercharged contour that is interested in testing it. Check your PM's foo, you've got someone with a 3L that's interested in testing it as well.  And next April I can answer the smog questions as well. Maybe earlier if someone wanted to spring for the $50 it costs to run it before then.
Posts: 5,296 |
So, when is this going to be available?
Posts: 5,296 |
Posts: 407 |
Ditto here. I've been following the EEC Tuner list and hope this is gonna be available if it'll help a 2.5L. My car's got a "flat spot" between 3-4000 rpm I bet I can tune out.
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
Posts: 49 |
I would be very interested in trying it out for the euro market. i have standard 170bhp with a few mods but there is no 115mph limiter, so i am worried about other diferences. do you think you contour program will work ok on my 97/98 mark 2 st24 mondeo?
Mondeo ST24 with RSAP body kit. 17" DOTz's on 215/40/17 goodyear F1's (very good tyre) EBC TURBO GROOVE FRONT AND REAR DISCS (rotors)(warped fronts exchanged under warrenty) EBC GREEN STUFF PADS (voted no1 in uk performance ford tests) k&N induction kit throttle body butterfly mod SHM HEADERS, Y & CAT Custom Exhaust System Ecotec Valve more mods to come... ice sony XR-M510 head unit sony 656 changer(cdr/cdrw/cdtext compatable)
Posts: 1,444 |
this is the biggest upgrade i'm waiting for. any updates.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 5,296 |
My 3L is going to be in the car soon. I hope this is going to come out soon or I'll have to drive like grandma for a long time...
