Posts: 26 |
My 98 'Tour is a base model that comes with the 14" steel wheels and plastic wheel covers. I picked up a nice set of Ford OEM 15" alloy wheels from eBay in the spring. These...
[image]http://f3.yahoofs.com/users/434d140dz4e13227b/ec4dre2/__sr_/caedre2.jpg?phwz7sEB7l5ghJyx[/image]
Now I've got the opportunity to pick up a very low mileage set of Toyo Proxes T1-S tires at a great price from a fellow NECOer. I've got the same Toyos on my Cougar for summer tires and they are fantastic. I want to use them for summer tires on the 'Tour and use the steelies for winter.
Is that wheel the stock SE wheel that came with 205/60-15 tires?
The tires I have a line on are 195/55-16. Is this an acceptable size? Not too narrow? I checked the tire size calculator, but don't have enough experience to decide if that size is close enough. Any thoughts on using 195/55-16 tires on those wheels?
Thanks.
Mark
2001 Laser Red Cougar V6 ATX
CougarFest 2006 1st (tie) Best Paint / 2nd Cleanest Car
CougarFest 2005 Best Stock
1998 Contour V6 ATX
1993 Tempo I4 ATX
Posts: 6,910 |
yes stock 15" tire size is 205/60-15 try this to figure out the size you need to keep the speedo correct
- 95 Mystique LS - Zetec/5spd
Posts: 5,345 |
Originally posted by Linkman: ... I picked up a nice set of Ford OEM 15" alloy wheels from eBay in the spring. .......
The tires I have a line on are 195/55-16. Is this an acceptable size?... Any thoughts on using 195/55-16 tires on those wheels?...
Your 15" wheels will not fit the 16" tires.
http://www.goodyeartires.com/kyt/readingATire/
BTW, did you get the wiring issue sorted out? If you did, post to close out the thread.
1996 V6 ATX 96K miles
Posts: 26 |
Sorry, typo! Correct size is 195/55-15
I do know enough to read the tire diameter, I'm just not clear on what is too narrow for a particular rim - if the stock tire that came on that rim is 205/60-15, is 195/55-15 too narrow?
Speedo is only off by I think 3 MPH at an indicated 60 MPH.
(No, wiring issue not sorted out just yet. Fourth holiday and CougarFest last week made working on the 'Tour a no-go. Will try to get back to it this week. Thank goodness for the still running Tempo!)
Mark
1998 Contour V6 ATX
1993 Tempo I4 ATX
Posts: 3,867 |
Width should be fine. The 205s are a little squeezed on the stock rim.
Your picture didn't work for me. Which OEM wheel is it?
Function before fashion.
'96 Contour SE
Posts: 26 |
Well, crap. Worked for me earlier, now doesn't work for me either.
The wheels are the silver painted alloys, eight spoke, center cap with a blue Ford emblem and fake screw heads ringing the center cap.
Maybe this eBay link will work... not the auction I bought from, but the same wheel.
Mark
1998 Contour V6 ATX
1993 Tempo I4 ATX
Posts: 3,867 |
I only ask because my early rims are 15x6.5", but IIRC, the ones you're talking about might be 6". Either way, I still think you're fine with the 195 width.
'96 Contour SE
Posts: 26 |
Originally posted by RogerB: I only ask because my early rims are 15x6.5", but IIRC, the ones you're talking about might be 6". Either way, I still think you're fine with the 195 width.
I believe that the auction the photo is linked from indicated 15x6.5 inches, but I will try to find something stamped on the wheel itself to be safe. I think I'll grab up those tires as soon as NewCougar.org comes back up from the hosting migration, so I can message the seller.
With Toyos on once the 'Tour is running again, I might be able to get through winter on the all-season tread that remains, but if I drive on them during summer/fall, the all-seasons will definitely need replaced prior to winter.
Thanks for the input guys
Mark
1998 Contour V6 ATX
1993 Tempo I4 ATX
Posts: 604 |
that is the rims that are on the 99 se sport. i am running those rims with 215 60 15 no rubing.. but stock size is 205 60 15
G/f's black 99se sport 5 speed
2 1/2 test pipe-custom cat back 3 single tip
cai with kn3530
safc optimized tb
8mm plug wires
spec stage 1 clutch
svt front bumper
