Posts: 3,637 |
any word on the TPS wire?
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
Originally posted by Tourige: any word on the TPS wire?
ya get a multimeter and check it, Jesus!
Posts: 1,746 |
I believe it was white when I had my kit on. Your best bet though, like everyone has said, check the wire
2000 Contour SVT
SF - #542 of 2150
Posts: 3,637 |
Its white, Just FYI for anyone looking.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 5,810 |
Its a 3 wire TPS. One wire reads high as the other one reads low. It depends what type of trigger you need on the kit. IF it triggers when voltage goes up, then measure the voltage on the wire with the key on an see which goes up as you open the TB. Otherwise if it triggers when voltage goes low you hook up to the other wire as that wire will read max voltage when closed.
See My Mods
Posts: 715 |
Originally posted by Decepticon: Nope Test!!!
The United States already does enough for your canadians soo you're on your own here.
I got a big fat FACK YOU right here, ass
Brian W. -------------------- Black 1998 SE 5 speed - TOTALLED
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
Some times the truth hurts buddy
Posts: 28 |
This board is on a downhill slide thx to some of you....
Posts: 715 |
Originally posted by converted_gm: This board is on a downhill slide thx to some of you....
I'll second that
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
Originally posted by BrianW: Originally posted by converted_gm: This board is on a downhill slide thx to some of you....
I'll second that
