#1606067 07/07/06 11:48 PM
About 5 days ago, I was driving and I noticed that when I accelerated, the engine sped up, but the car was slow to respond--it hesitated, then sped up. Then "O/D Off" light started flashing. I checked to see if I accidentally disengaged the O/D button. Nope, it wasn't disengaged. Earlier that day, I noticed that the coolant sensor light came on briefly and then went out. I checked the coolant level, it was okay. No leaks detected either. Also, I noticed a an odor which smells like burnt rubber. Could my timing belt be on the way out? Or could it be something else?
Here are the stats on my car.
Model: 1998 SE Sport, 6 cyl., auto trans.
Mileage: 97,000
Work done (most recent to least recent): New alternator, new battery, and water pump.
#1606068 07/08/06 07:23 PM
The Duratec uses timing chains instead of a belt, so I highly doubt those are on the way out.
The coolant light is finicky with 'Tours. The coolant level probably dipped below the sensor for a second, which caused the dash to light up. Happens all the time. The remedy is to keep the coolant level a half-inch above the MAX line.
The flashing O/D light thing happened to me a while back, never figured out what caused it. It only happened once, and it went away when I restarted the car. Maybe something with the transmission, or electrical?
Good luck.
RIP 1997 Mercury Mystique LS - 2.5 L Duratec "Everything that's good is gone...." - Fuel
#1606069 07/09/06 12:13 AM
You will need to read your codes to see why the O/D light was flashing.
I'd suspect, based on your additional symptoms, that a P1744 will come up which means your torque converter is slipping. Repair would be a new TC, solenoid block, and a rebuilt valve body. That's $600 in parts and requires removal of the tranny to replace the TC.
You might get lucky and get by with the VB and solenoid assy along with a fluid flush, but by your mileage and with a slipping TC, I doubt it.
Get the codes first. OBDII scan tool. Just speculating right now.
Steve
#1606070 07/09/06 12:25 AM
N
N
When the OD light was flashing on my atx mystique the trans was overheating and barfing all over its self.
This happened 3 times before I god some high quality tranmition fuild. Never happend again.
